San Diego RCS OTAP
P25Radio
Oceanside Ca.
Wonder what talk group or channel the RCS uses to reprogram radios or does each department have their own assigned
channel?
d119
Patch & Channels Clear...
EM1's guest house.
OTAP is extremely slow and painful, and I doubt it's even being used. It requires the radios to be authenticated in the back end and a whole bunch of other rigamarole to make it work (IP addresses, etc.)
The FNE initiates the session on whatever channel is available, just like a voice call. It's not a "talkgroup" per-se, but more of a function.
It also requires the subscriber radio to have the feature in the flashcode, and I seriously doubt any of these agencies paid for anything they didn't absolutely need.
Less features = more radios.
f40ph
Largest County, CA
SLOW and PAINFUL is right. OTAP isn't recommended for fleet updates. One radio here and there might save someone a drive but that's about it.
Our system just requires the radio be sitting on any trunking channel. The update happens in the background via the trunking data channel.
d119
EM1's guest house.
I think it actually establishes a P25 data call on what would normally be a voice channel, but still - the transfer rate is crap.
f40ph
Largest County, CA
That's very interesting. I've watched my radio while receiving OTAP programming and it did receive voice traffic, maybe it pauses data during voice on the selected TG?
d119
EM1's guest house.
Entirely possible. You certainly wouldn't want the thing running an OTAP update during a critical incident, so perhaps it does it that way so that's not a concern.
I have no personal experience with OTAP in a Motorola environment such as the RCS, but I would expect it to use packet data for the transfer rather than the control channel, as I would think it would cause an undue amount of contention on the control channel and impair system accessibility.
Most of the OTAP I'm familiar with does so over LTE or another broadband-type connection (WiFi in my particular case). If the radio has an update pending and it comes within WiFi range, the user is prompted if they want to receive the update or not so it doesn't drop them in the middle of a critical call. OTAP over LTE/BB happens in a matter of seconds.
WayneH
Forums Veteran
Your master site
OTAP/POP25 utilizes the standard packet data system built into the ASTRO network (hence IV&D, integrated voice and data). Data calls are a separate thing and indicated specifically in the P25 CAI. It's a convoluted side of the infrastructure in how it all works but basically a radio will do a context activation after registering on the system; this process is similar to how a computer requests an IP address when it isn't assigned a fixed/static address. There's an assortment of infrastructure that makes this all happen (GGSN, PDR/PDG, Border Router) so that the system keeps track of the the radio network so the data calls can be sent efficiently. The device called the border router is the last router before the IP data that a subscriber initiates is introduced to the network where your data services are (so KMF, Radio Management, AVL, etc). To add to that, services such as AVL and OTAP can use encrypted data via an added device in the packet data network. The KMF is natively encrypted so these other services rely on a packet data encryption gateway to handle the other packet data services. This packet data network is often connected to the customer's private network where their CAD system resides to there's inter-operation between CAD and subscriber database (UCS aka Provisioning Manager) (for example).
From a scanner perspective you'll have no idea this is going on unless you monitor in conventional. Data calls don't utilize groups, but you will see radio IDs during the calls. Channels by default can handle both voice and data, with voice taking priority and you can enable the ability to pre-empt a data call for voice if the system loads up. Voice and data can be an and/or if you so want to dedicate a channel for data (see enhanced below). Calls are sequenced like people lining up at a bank.
Then there also an enhanced data format (you'll see it in a flashcode) that's typically associated with AVL and adds abilities like the ability to send location on PTT. When AVL is used on a system you'll see quite a lot of data calls. There are a lot of options as far as location goes, and some can send data often.
The smart way to do OTAP is to sync over WIFI to the radio management server and get the programming jobs that way.
2wayfreq
NM Kirk City
Unless they have a good deal on Radio Manager Server, it's very expensive for licenses. I believe you can run it though Wi-Fi/Hot Spot networks for much faster multi-radio updates. Using Trunking Data speeds for OTAP is not ideal in a huge network.
jmarshl
San Diego, CA
I agree. I just received a very large codeplug from radio management via WIFI in under 2 minutes.
Anderegg
Enter text in this field
San Diego
RCS doesn't utilize OTAP. (this is causing issues for SDPD encryption reprogramming for the RCS)
San Diego City does use OTAP and OTAR, but via WiFi at station installed access points...this is why you see all those new WiFi dome/pucks on all the police cars now, so they can OTAP in the parking lot.
Paul
d119
EM1's guest house.
Paul
Couldn't have anything to do with uploading MVARS recordings either, now could it.
I'd be VERY surprised if that's what any of that is for. More than likely there's a cellular router in each vehicle that transfers all that crap, creating an in-vehicle WiFi network for the MVARS, radio, MDT, and whatever else.
Most of that "station based" stuff went out the window when cellular became the choice for mobile data. Just send it all that way, and have it instantly rather than waiting for the car to come in.
Change your avatar, weirdo.
Anderegg
San Diego
From my understanding, the WiFi pucks were primarily installed along with the APX deployment, which is 99.9% complete, save for a few old 800MHz only XTL2500's in some random forgotten cars.
SDPD also doesn't have MVARS at this time, to my knowledge, and recording devices such as on car LPR's have been disabled due to civil rights complaints, so not much else besides Verizon internet possibly using the pucks.
Paul
d119
EM1's guest house.
Paul
I'd wager those antennas are probably connected to something like a cradlepoint router rather than the APX. Unless SD City is using the radio system for AVL.
Pittsboro IN
I left San Diego in 2017, are they using Flock cameras now? I remember the senior volunteer patrols would run LPRs, hard to see why anyone would say it's a civil rights issue. Don't I have a right to know if someone is driving my stolen vehicle?
JeremyG760
Oceanside, CA
I haven't paid a ton of attention to anything recently, but the civil rights issue is more related to data retention. Its not just knowing if a car was stolen. The system logs every plate it sees, where it sees it, and when it sees it. That information has been getting stored for unknown amounts of time, and is accessible to law enforcement for unknown reasons. Many agencies have published data retention and access policies, but not all. I recall SD County's policies being controversial but I can't recall why.
With the switch to Flock for many places, this has gotten muddier as the Flock systems don't seem to have any published data retention policies, at least when I've tried to find them for my city.
Pittsboro IN
I wonder how Flock handles data from private users like the Indy motor speedway or the shopping center down the street from it?
"public" agencies seem to have this idea that they will decided what is public and what isn't, even though public money is spent to buy equipment.
Peter_SD911
Scan Sexy
Surfridge, CA.
Lowes( Carlsbad) and Home Depot have LPR's at the entrance and exit of their parking lots. Ca and AZ. Black mono poles with solar panel. Just like the ones in the county and all over Riverside County.
Pittsboro IN
Our town has 8 but we are so small vehicles can be out of town by the time the system processes the info and sends an alert.
I don't recall seeing any utility markings for those poles they put in, I wonder if they call 811.
Anderegg
San Diego
I was informed that the "civil rights" issues arose from the LPR's getting more "hits" in minority neighborhoods, so they just disabled them citywide on patrol vehicles.
SD City ALPR policy https://www.sandiego.gov/sites/default/files/lpr-surveillance-use-policy.pdf
Paul
