Sangean 909x Antenna input issue
N0WPX
Hi,
When I fully insert an external antenna plug into the jack I get a weak signal, but if its half way out the signal is good. Mono or stereo plug it doesn't matter.
Is there an issue with the jack on the radio?
Dirk_SDR
Germany
Yes, it is possible, that the tip contact in the jack is a bit bent away from the plug's tip contact.
If you then pull the plug out a bit, the cone-shaped tip of the plug touches the jack's contact again.
krokus
Southeastern Michigan
Sangean appears to use a TRS (or stereo) socket. The pinout seems to be disputed.
I have a stereo to L & R socket splitter, which I am experimenting with on mine. I use a mono plug from an antenna, which I move between the ports, with the stereo end in the radio. So far, I have not been able to sort out which works better, but I have a high noise floor. Now that the weather in Michigan is getting nicer, I will experiment with a loop on ground, with a 9:1, in a park. (When I get some spare time.)
N0WPX
I fixed my issue by getting a stereo plug extension and rewiring the tip to the ring.
Boombox
Try a mono plug? It worked on SW for me (on my DX-398/Sangean 909) for years.
N0WPX
I did try mono plug and even tried reversing the wires on a mono plug before the stereo plug. I don't know why its working this way, but I'm glad it is and it was a cheap fix. I wanted to get this posted incase someone else runs into this issue with their 909x
