I'm not 100% sure that it's FleetSatCom8 as my yagi is only a 4 ele it would have quite a wide receive footprint. From where I am, FSC8 has an azimuth of 241 deg yet the antenna points roughly at 160 deg !! It could be one of the three SKYNET sats between 140 and 170 deg as I've heard brazilian pirates talking on those recently also. However, you are assuming FSC7... which is at 105 deg ??? Is that sat active ? I'm confused
That antenna is great, the signals you are getting confirms that. It's dark here now so I'll try and get a pic of my antenna tomorrow.. if it's not still raining. But I have it temporarily hanging off a sweeping brush on my apartment balcony
. In your second screen shot, I can see you are getting a bank of channels from a UFO sat at around 243.9 MHz. I've attached a pdf that gives those frequency details.
Check if you can receive the 'WaterDripper' from the Milstar sats around 243.785 or 243.825 make sure to use USB mode.
Here's what I'm receiving at the moment....
