Saugus police
epilab
Mass
Have not heard any communication for the past 4 hours this evening
A bit unusual
Any one notice the same thing or is it just a quiet evening
ecps92
Taxachusetts
Rte-1 quiet?? ha ha ha
They are active this am [8a-9a ish]
IS this the only agency you are not hearing ?
If multiple agencies, it could be you antenna / coax / connection
or even an in-advertant hit of the Attenuation button
A bit unusual
epilab
Mass
Yes
They have had communication issues so not sure if upgrade in process or using a secondary frequency. Even daily shift info no coming in
All other surrounding agencies remain as usual
ecps92
Taxachusetts
Getting them Loud and Clear here to the south with a stock antenna, so I would suggest
a. Double check you didn't lock them out
b. Double check you didn't ATT them [attenuation]
Yes
epilab
Mass
Finally heard one unit on. Very poor signal. I am close to station. No FD issues
Maybe they may be just quiet
Thanks for all reply’s
ecps92
Taxachusetts
Well if you are getting them weak and in Saugus [PD Station has no bearing, as that is NOT where the Repeater is]
and I am getting them real strong on the South Shore, you need to double check you settings [as previously indicated]
epilab
Mass
Only heard one transmission this morning
If there have been more please let me know
ecps92
Taxachusetts
IF that is the case, all solutions point back to your end.
Again if I am hearing them, South of the City, with no issues
Stock, inside antennas - then the issue is on your end.
As I type this [2pm] they have been talking
epilab
Mass
Caught a routine stop. Guess things are just quiet
Thanks for info
