Scan Cat Lite Plus ??
derekn
Kanata
I have a copy of this program I used when I ran windows XP, does anyone know why it will not work with Windows Vista
I use it on my BCT8
TES
America's High Plains
I have a copy of this program I used when I ran windows XP, does anyone know why it will not work with Windows Vista . . .
Best ask Jim Springer. For some reason he's never seen on this site:lol: Suggest you Google 'Scancat" and ask Jim directly. Good Luck!
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
As has been discussed here many times, Scancat Lite Plus is a real POS. You should use that software only if there are no other packages available, and in this case, there are.
You would be far and away better off using ARC8 from BuTel (available via Scanner Master) or Scan Control . ARC8 has the advantage of being able to connect to the database via the web service and download data, so long as you have a premium subscription (cheap). Scan Control has a copy/paste utility which works with the database without using the web service.
Best Regards Mike
