Scan function on XPR3300e
hmadud13
Hello,
I tried programming either of the 2 buttons on the side with both combinations of short and long press and can't seem to get the scanning function to work. Is the LED supposed to flash differently when scanning or something, maybe it is working and I am not aware of it since there was not much chatter when I tested. I am using CPS 2.0 Version 2.153.167.0.
The weird thing I saw in CPS, the radio buttons on the left side of my radio don't what I see in the CPS. Is that normal, since I only have PTT button and 2 round buttons, one blank and one with the dot. I programmed the blank button for Scan On/Off short press and I have created a scan list. Thank you in advance!
K2NEC
5F6
Did you assign the scan list to your channel? Did you add the channel in the scan list?
K2NEC
5F6
So what exactly happens when you press the scan button? Do you hear any tone? The LED is supposed to blink orange while scanning
hmadud13
ok short pressing the dot button played some sound (and LED is flashing orange
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
Are the channels setup correctly with correct frequency, color code, slot, and TX contact?
What exactly is is NOT doing?
TT
kk6rq
Clear Lake, IA
He nailed it; I see channels assigned a scanlist but nothing to indicated the list is populated. Obviously the issue... Put channels into your list... then scan will work...
