I downloaded from the database (under Oregon, Lane, County Systems) Pacific NorthWest DMR. Created and added it to its own favorite list. Set the FL quick key to 8. When I enable it on the scanner, says nothing to scan. Looks like the list has frequencies and talkgroups. I have DMR enabled on...
Yes, but be sure to change the target model to 436HP(under tools) first. If you forget to change the target and load the SDS profile on your 436 it will not restart and you will have to "clear user data" and reload to get it started. After changing target to 436HP do a save as 436HP then change target to SDS100 and save as SDS100 and you will have 2 configurations saved with the same Favorites in both configurations.
