scan vs system model Lpe-200
Hello All,
Just curious, is the programming process the same with progamer the same between the scan and the system model?
Cheers
Forts
Ontario, Canada
Basically, yes. There are obviously a few more buttons on the system model that can be configured.
Radio1114
Is the cable the same on both for programing both radios?? Thank You
ElroyJetson
Even the same file is used. You just have to change the radio type from system to scan before hitting the program button.
My personal preference is to set up the rotary knob as the system selector (usually set up to select specific agencies you'd want to listen to) rather than the default groups selector.
When scanning, it makes more sense to be able to use the knob to change agencies. At least, that's what I think.
Elroy
