ScanAmerica Ohio
jasonk
Dayton, OH
Please consider providing a Scanner Feed if your County is not covered by the Ohio Scanamerica Feeds. It is very simple and takes no resources or bandwidth.
Jason
rdale
Lansing, MI
It does take resources (gotta run the software plus add a scanner), but I'll agree than bandwidth is not an issue.
jpryor
Nashville / Green Hill TN
I have multiple analog only scanners available to individuals who want to a host a feed in any uncovered areas within Ohio. Contact me if you need an extra scanner that will be used for a ScanAmerica feed.
mdulrich
Van Wert, Ohio
what software does it take to povide a feed. I may be able to do lawrence county.
If you agree to provide a feed they will send you a file which will set up Icecast on your computer with the necessary settings to connect with their server.
Mike
