PRO-93 battery
PRO-93 owners manual.
Pages 10, 11, and 12 talk about power.
Black battery holder can hold rechargeable or non-rechargeable batteries but will not charge the batteries if the radio is plugged into a 12 volt or 110 power supply. If you want to use the black battery holder you will need to buy an external battery charger like I mentioned above.
Yellow battery holder is for rechargeable batteries ONLY. It will recharge the batteries while they are in the scanner when using external power. You never, ever, ever put nonrechargable batteries in the yellow battery holder.
Like someone mentioned above you can use the yellow holder for your NI-MI rechargables and keep a set of regular nonrechargable in the black holder for when you are caught out and about without a charger.
One last note...
Some people never recharge their batteries in the scanner perferring to use an external charger, others use the builtin charging circuit in the scanner by just plugging the external power supply into the scanner. I do both myself depending on the sitution at the time.
Pro-93 does not have a switch. it has the black and yellow battery holders.Gilligan said:I've read down the other replies and someone mentioned to check the switch in the battery compartment. This seems like the most likely source of your problem. If you are using regular Alkaline batteries and the SWITCH is set to rechargeable, then it's probably trying to charge your alkaline batteries. Double check that switch -- it's critical.
One last note...
