scanner filter question
scannersnstuff
o.k. here's my dilema. i recently replaced 1 of my bct-15's with a bcd996xt. the xt is more sensitive.
i have a radio shack discone <the $79.00 one> in my attic. i run the coax to a stridsberg 4 port multicoupler to run a combination of scanner's. i have a powerhouse fm station probably less then an air mile from my house. in the past it has interfered with my vfh-air band reception. this is the case with the 996xt now too. in addition, my local pd broadcast's on a 154. mhz.fq. their main antenna site is about an equal distance away. it seem's that now when they talk, it's splash's all over my other vhf-hi frequencies in my bcd996xt. my question is, i know very little about scanner filter's. is a fm radio/vhf-hi filter available ?. if this combination was in place,would it reduce all the signal's in my vhf-hi band ?. i took a look at some scanner master and par filter's.
scannersnstuff
thank's,it does help somewhat. i looked at those.my question's still pretty much remain the same.
JLM7424
Williston,ND - Williams county
OK I would suggest this one for sure it will illiminate the radio station and all hf noise
HPN-30118 Combined Notch Filter.<---put b4 multicoupler.
I have that multicoupler it does somewhat amplify ..how close to your radios is it ? further from radios with longer jumper could help running into same problem with my outdoor antennas a work in progress
Now What you want to listen to how far is is it ? does it come in strong if so ?
Then use This and adjust accordingly .
ATT-20 Variable Attenuator
maybe it helps maybe Not been playing with radios for 20yrs and thats what i would try.
Good luck!
k4njk
Coral Springs, FL
The best solution would be two separate notch filters in series. The problem, as you noted, with notch filters is that they attenuate a frequency range. That's not typically a factor with an FM notch filter since you want to eliminate a wide range of frequencies but a good notch filter at 154 Mhz will notch from at least 152 Mhz through 156 Mhz. That could be a big problem. From personal use I can recommend PAR Electronics filters. (PAR Electronics - Scanner Filters) Call Dale directly at PAR and speak with him. They can custom tune the filters and his prices are very reasonable for what you get.
scannersnstuff
seriously, thank's guy's. for now i've disconnected the multicoupler. i'm running 3 seperate scanner's off of 3 antenna's.
N3LLO
New Ipswich, NH
I also had a great experience dealing with Dale @ PAR. I needed a notch filter for a very strong WX station nearby. That filter works like a charm (in-line before my 4-port Streidsberg).
scannersnstuff
if i had to boil this down to 1 non confusing question, it would be. can a filter work across the entire range that i need attenuated ? a fm station in the 100's and a vhf-hi frequency in the 154's ?. other than those two, my reception is pretty much clean. thank's again.
JLM7424
I would Say 1 filter No !
a Fm stereo filter and a custom or pre made notch for that one particular freq yes
What freq range do you want to listen to ? or what are you listening to when you get interference from 154.xxx freq ?
