400 mhz is a frequency band.If a frequency has a 400 level frequency followed by "Repeater (DMR)" what type of scanner would I need to listen to that. Could the same scanner pick up a 100 level frequency that has a mode of "P25e" (not sure what this stands for) or "FMN"?
DMR and P25 are both digital formats, but not compatible with each other.If a frequency has a 400 level frequency followed by "Repeater (DMR)" what type of scanner would I need to listen to that. Could the same scanner pick up a 100 level frequency that has a mode of "P25e" (not sure what this stands for) or "FMN"?
Shelby and Christian County IllinoisBefore we go into what scanners are out there and might fit your needs, let's see where you are (county and state is fine) and what system(s) you want to hear. We can then put eyes in your area using the frequencies in our database. Once we know all of this, we can proceed.
Mike
For your area I'm also in IL you can get away with the 436hp unless you want to listen to ISP or any state agency then you would need the SDS100Shelby and Christian County Illinois
A bit of clarification. Some STARCOM21 sites (like sites 226 in Shelby County and sites 227 and 265 in Christian County) each have their transmitters at a single location. The BCD436HP should be able to receive those sites with no problems provided that you have an adequate signal at your receiving location. It's when you try to listen to what is designated as a 'simulcast' site (like site 263 in Sangamon County) that the BCD436HP has issues. With a simulcast site, the same signals are being transmitted from multiple locations at the same time. Generally, the '436 doesn't do such a good job in handling this, and as a result the transmissions often sound choppy and broken. However, the SDS100 and SDS200 excel in handling simulcast sites.For your area I'm also in IL you can get away with the 436hp unless you want to listen to ISP or any state agency then you would need the SDS100
Kevin you are correct. From my location in Bensenville, I run all of site 101 on my 536hp and for some reason even though it's a simulcast site I have no issues with DuPage agencies all come in perfect. For all other sites I use the SDS200. Kevo this is Antonio (KB9WUV) remember I worked at the Daley Center Courts.A bit of clarification. Some STARCOM21 sites (like sites 226 in Shelby County and sites 227 and 265 in Christian County) each have their transmitters at a single location. The BCD436HP should be able to receive those sites with no problems provided that you have an adequate signal at your receiving location. It's when you try to listen to what is designated as a 'simulcast' site (like site 263 in Sangamon County) that the BCD436HP has issues. With a simulcast site, the same signals are being transmitted from multiple locations at the same time. Generally, the '436 doesn't do such a good job in handling this, and as a result the transmissions often sound choppy and broken. However, the SDS100 and SDS200 excel in handling simulcast sites.
Hope this helps...
