BCD325P2/BCD996P2: scanner help
kb5vjv
novi, mi
I am trying to program in certain sites into my scanners . They are part of MPSCS
Michigan's Public Safety Communications System (MPSCS)​
I am trying to just be able to scan a few fire dep, ems and hospitals . I can add them to my scanners, but if i dont add the whole MPSCS dayabase i cannot scan theones that i want . I cant lock the other ones out or delete them. If i do my scanner says Nothing To Scan ,
There are a few sections i want to scan, one of them is this one . There are 4 other sections i want to monitor . But if i add just the below section and the other for, i get the dreaded Nothing To Scan .
I thought i kinda understood trunking, but i must be missing something . Scanning the whole MPSCS isnt a problem for my BCD436HP, but i bought a BCD325P2 , but it is way to slow to scan the whole MPSCS database . Side by side, the bcd325p2 is so slow i can hear the BCD436, but the BCD325 never hears what the BCD436 does at the same time. On its own the BCD325 will hear what i am wanting, but only if i am lucky enough for it to catch the site in transmition.
Both scanners have the exact same database loaded .
Does anyone have any ideas ?
Thank you
Oakland County (63) South Zone Fire
DEC HEX Mode Alpha TagDescriptionTag
320967d60T63FHFD1Farmington Hills Fire 1Fire Dispatch
320977d61T63FHFD2Farmington Hills Fire 2Fire-Talk
320987d62T63FHFD3Farmington Hills Fire 3Fire-Talk
321557d9bT63BHFIRE1Bloomfield Hills Fire 1Fire Dispatch
321567d9cT63BIFD1Birmingham Fire DispatchFire Dispatch
321577d9dT63BIFD2Birmingham Fire 2Fire-Talk
321587d9eT63BIFD3Birmingham Fire 3Fire-Talk
321597d9fT63CTFD1Commerce Twp. Fire DispatchFire Dispatch
321637da3T63CTFD2Commerce Twp. Fire 2Fire-Tac
321657da5T63BTFD1Bloomfield Twp. Fire 1Fire Dispatch
321667da6T63BTFD2Bloomfield Twp. Fire 2Fire-Tac
321677da7T63BTFD3Bloomfield Twp. Fire 3Fire-Tac
321687da8T63BTFD4Bloomfield Twp. Fire 4Fire-Tac
321697da9T63FHFD1Farmington Hills Fire 1Fire Dispatch
321757dafT63FEFD1Ferndale Fire DispatchFire Dispatch
321767db0T63FEFD2Ferndale Fire 2Fire-Tac
321777db1T63FHFD5Farmington Hills Fire 5Fire-Tac
321787db2T63FHFD4Farmington Hills Fire 4Fire-Talk
321807db4T63FBFD1Franklin-Bingham Farms Fire DispatchFire Dispatch
321817db5T63FBFD2Franklin-Bingham Farms Fire Dept. 2Fire-Talk
321917dbfT63HPFD1Hazel Park Fire 1Fire Dispatch
321927dc0T63HPFD2Hazel Park Fire 2Fire-Talk
322057dcdT63LTFD1Lyon Twp. Fire 1Fire Dispatch
322067dceT63LTFD2Lyon Twp. Fire 2Fire-Tac
322077dcfT63LTFD3Lyon Twp. Fire 3Fire-Tac
322297de5T63MHFD1Madison Heights Fire 1Fire Dispatch
322307de6T63MHFD2Madison Heights Fire 2Fire-Talk
322327de8T63MIFD1Milford Fire DispatchFire Dispatch
322337de9T63MIFD2Milford Fire 2Fire-Tac
322347deaT63MIFD3Milford Fire 3Fire-Talk
322407df0T63NVFD1Novi Fire 1Fire Dispatch
322417df1T63NVFD2Novi Fire 2Fire-Tac
322427df2T63NVFD3Novi Fire 3Fire-Talk
322437df3T63NVFD4Novi Fire 4Fire-Talk
322447df4T63NVFD5Novi Fire 5Fire-Talk
dave3825
Suffolk County NY
Need to know which sites your programming. If they are simulcast, that scanner might not be the best choice.
I don't think the 325 is a database scanner. Do you mean same programming? What are you programming that, and the 436 with?
wtp
Port Charlotte FL
2 (2)001 (1)HollyOakland769.90625770.15625851.6125851.6375852.1125852.2875852.4125
852.8125852.8375853.425c853.925c861.2875861.9875
2 (2)002 (2)LakevilleOakland774.08125774.83125851.2875851.9875852.2375852.275852.4875
853.1625853.200853.4875853.5125c853.6625c853.950c862.1125
862.5625
2 (2)004 (4)Beech Daly (Southfield)Oakland770.40625773.08125773.83125774.84375851.0875851.400851.4625
851.4875851.7875851.9625852.4625c852.9625c862.3625862.4125
862.4375862.5375862.6625
2 (2)007 (7)PontiacOakland770.65625773.58125851.2375851.5375851.925852.8875c853.4625c
855.9625862.1625862.2375862.4875862.6875862.7875
2 (2)027 (1B)Oakland County SimulcastOakland769.36875769.61875770.11875770.76875771.19375771.46875772.41875
772.81875773.16875773.46875774.14375774.66875851.350851.6625
852.6125854.4125c855.0125c855.2875855.6625c855.7825860.6875
860.7625c
if you try and listen to every tower the radio will spend 8 seconds doing "housekeeping".
that means it checks out the other towers/systems to see if there is something you might want to hear on those.
even if you set HOLD to 0 it still needs 2 seconds.
HOLD is not DELAY.
DELAY is the wait time after a transmission/squelch break.
i try to listen to on thing with trunking systems (one tower/site)
kb5vjv
novi, mi
Oakland County (63) South Zone Fire​
Oakland County (63) Central Zone Fire​
Oakland County (63) North Zone Fire​
Oakland County (63) EMS​
Oakland County (63) Hospitals​
the 325 is a BCD Bearcat Digital . It is programmed he exact same way my 436 is. I use Proscan
kb5vjv
novi, mi
862.5625
860.7625c
HOLD is not DELAY.
How can i add just the 5 i listed without adding everything else .
I will add the ones you listed above and see if that works.
I am thinking about returning the 325 and getting the desktop BDC536
enosjones
Price, Utah
the database will let u scan whats on the database if u downloaded from it using sentinel, u need to create a favorites list, turn on the quick keys u want On and service types.
enosjones
Price, Utah
also a good idea to turn ID search on as well , full database won't let u do that it will need to be on a favorites lists
kb5vjv
novi, mi
just wanted to say Thank You to everyone for the help . I was able to keep the 5 sites, and just added Oakland County simulcast, and was able to to get just the Fire ,EMS. Hospitals and Rescue. All law enforcement in oakland county is scrambled. I have a few other trunked systems and alot of conventional systems, but keep them in their own fav list, air, wx, rail, ham andd a few others. Then i can just turn on any list i want to monitor . My 325 does much better now, with a much smaller scan list .
Thank you to everyone ..
enosjones
Price, Utah
bcd325p2 may struggle with simulcast, it may be come distorted or not come across as well. or traffic may get missed
Melvin22
Key question here is whether the scanner is used fixed position or mobile. It is definitely possible to work with antenna configuration/scanner positioning/device settings to get good results with Simulcast. I, and many other users here, have had success. A non stationary application would make me lean to the MUCH more expensive top of the line SDS100/200 but otherwise I will save the hundreds of dollars, thank you.
