BCD325P2/BCD996P2: Scanner not picking up broadcasts?
CalJ
Just got a new Uniden BCD996p2 and am having trouble getting it going. I used the Freescan software to program it.
I received a few small broadcasts right after but nothing since.
I'm not sure if used the software correctly or if need to change a different setting or not.
Shenandoah County, VA is the programming I'm trying to set up.
CT
CalJ
This is the one I'm trying to set up.
The control frequencies are under sites, and the others are under groups. I've tried both ID Scan and ID Search.
Should I be using the one you liked to instead?
It seems to be scanning only the control frequencies, should it be scanning the others as well?
hiegtx
Dallas, TX
Is this the system you're trying to monitor?
Review the procedures for programming a trunked system here:
Programming Trunked Systems
And see whether it helps to use
ID Search Mode to see if your programming is correct.
Looking at the county's database page, it looks like that county is not using STARS. Also, there's no STARS site listed for the county.
CalJ, are you trying to program the conventional channels listed for your county?
While not linked on the county's page, it appears that your county's Sheriffs Department, as well as county fire/ems, also have talkgroups on this system: Shenandoah County Trunking System, Shenandoah County, Virginia
That is a P25 Phase II system, which the 996P2 can monitor. However, both the sites used on that system are Simulcast.
That can be a problem for any current model scanner other than Uniden's SDS100 & SDS200. More about Simulcast & the problems it causes receiving that type of system are in the Wiki. Simulcast digital distortion - The RadioReference Wiki
If you have saved your FreeSCAN file, attach it to a post so that someone can take a look and suggest any changes that might be necessary FreeSCAN files have the extension *.996. Find your file where it is saved on your PC using Windows Explorer. Right click on your file. You'll see an option for "Send to". Select that, then use the option of sending it to a 'Compressed (zipped) folder. That will create a copy of your file with the same name, but with a file extension of *.zip instead of *.996. You can attach the zipped file to a post.
In FreeSCAN, for System type, FreeSCAN imports it as "Mot Type II/P25". Instead of that, change the system type to "P25 Standard (Digital XT)". That may, or may not, make a difference, but it's worth a try.
CalJ
This is the FreeScan file I used. I did another upload with the change to the P25 Standard (Digital XT) and changed the squelch to 2. It started broadcasting some more but not what should probably be getting. Also it did pull some errors during the upload "Unable to set WX" and then no APCO band plan available for either North or South Simulcast.
Also I am new to most of this so not fully up to knowledge on some of this. I know that the local system went fully digital earlier this year, so not a conventional. Was told needed a scanner that did P25 Phase 2. Not sure about STARS system or simulcast. We have both the info from Radio Reference and also a local sheet with local broadcast info. The top of the page lists old school frequencies as control groups and below that are the new 4 digit numbers listed.
  • BCD996P2 12-25-2022.zip
Brales60
Punta Gorda, Fl
I went through the 996P2 deal in my area, so much distortion due to simulcast. Ended up getting a SDS200 and life is good, huge difference. I've read about the SDS's analog performance woes, but I just don't get them. Maybe it the external antenna which I believe makes a huge difference overall.
hiegtx
Dallas, TX
The "error messages" generated by FreeSCAN for 'Unable to set WX' and 'no APCO band plan' are normal for that software, and can be ignored. The first time or two you download a file from FreeSCAN to your scanner, you'll see those messages. Just ignore them. After the first coulpls of times using that file, the messages will disappear. It's telling you that you did not set up the Weather (WX) for the S.A.M.E. codes for your area, Zero effect on scanning your programmed systems.
The 'error message' for APCO Band Plan can also be ignored. The scanner will get the band plan data needed directly from the system's control channel data. Once again, even though you did not fill these in, the scanner will handle that itself, and there are no issues regarding reception.
On your file, it was still showing as "Mot Type II" for system type. I changed it to P25 Standard. I also added the conventional channels listed for your county, and attached the updated file to this post. Download the file, & extract the program & load it into FreeSCAN. Then use FreeSCAN to send the file to your scanner.
For the trunked system, simulcast can be a major issue. See the Simulcast Wiki page referenced in my earlier post.
You may try using 'less' antenna, using the antenna you received with the scanner fully collapsed, not extended. In some cases, laying the antenna flat on your table or desktop, instead of vertically, can help. You might also try moving the scanner around in your house, to see if you can find a 'sweet spot' that works. Depending on your exact location relative to the simulcast sites, in some cases, you can use something like a metallic baking pan, set next to the scanner, to block signals from one direction, and see if your scanner can receive a location that is not blocked off. A directional antenna, such as a yagi, aimed at one specific transmitter, works for some.
  • BCD996P2 12-25-2022-a.zip
CalJ
Thank you all. I am now getting signal. Fixed the programming. Also lowering the squelch and making the antenna shorter made a difference.
