Scanner Repair
DeepCover757
Norfolk,VA
Does anyone know of any good scanner repair shops in the Hampton Roads area? I have a couple of old radios that need some minor repairs to the bnc connections that I can't fix. Thanks in advance.
CVASSB
Louisa County Virginia
I have a Radio Shack Pro-96 that stopped working,that I wanted to keep. I took it to Radio Shack,and they sent it off to be repaired. They put a updated version of the Pro-96 CPU in it. It was not cheap.
If you want to buy a good scanner,my advice would be to buy the GRE-PSR-800. It is a user friendly,and in my opinion the best scanner out there.
krokus
Southeastern Michigan
Wirelessly posted (BlackBerry8530/5.0.0.973 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/105)
What brand and model of scanners? Some people might be willing to tackle older stuff, that might not be willing to work on newer stuff.
brownlab
Washington DC, Alexandria/Fairfax County /Loudoun
I would try a place like Discount Two Way Radio Repair if you are just looking for some one to do some BNC work for you. You will probably have to send them the units but they are all over the place. I might also try a marine store that sells radios. There must be serveral of them in Norfolk.
Two-Way Radio Repair | Motorola, Icom, Kenwood, Vertex
However there are not many places that do work on older scanners. I had a Uniden 250D scanner that just needed a new power port but I could not find anyone who wanted to work on it. Sometimes it is just cheaper to upgrade but in your case, these guys will probably do the BNC work fairly cheaply. Good Luck
