Scanner search
92naron
Blaine, WA
I am a wheelchair bound person with MS and enjoy snooping with my scanner. My unit is an old HH Uniden and I would like to upgrade to a base scanner/exterior antenna. A ny suggestions on a not to expensive unit?
My area in NW Washington is still analog.
N8IAA
Fortunately, GA
I'm going to suggest a Uniden BC15X. To bad they don't make a base version of the 125AT.
Larry
localknitwits
buzzards bay, ma
I second the BCT15X. Great scanner. Just use software to program it which makes it 1000x quicker and easier. Programming it manually is simple to but takes a lot of time. There's a lot of extra features on the scanner which I'll probably never use but its nice knowing if I want to they are there.
greggk
York,PA
I realize you said not to expensive, but if your area is now or in the future planning to upgrade to the newer systems, you might want to consider a scanner that can receive Phase 2 transmissions.
The scanner above is not digital as well. Scanner master sells it for $189.00.
My only reason for this advice is that I hate to see someone buy a good analog scanner, spend $200.00 + on it, then find out 6 months down the road you have lost a lot of your scanning capability due to radio upgrades.
I just like to prepare for the future if possible.
As always..just my humble opinion. Good Luck
Greg
N8IAA
Fortunately, GA
His county, plus one city uses LTR Multinet. The city he inquired about is conventional analog. I'm sure that he is good to go with the 15X.
Larry
