Scanner Selection Help North West Arkansas
Scanning-Hog
You can drop $650 on an SDS100, or if you're on a budget, why not give the two SDR dongle route a try?
I was in Little Rock a few months ago and I was able to monitor the LR Metro simulcast system very well using my laptop computer and two SDR dongles running a program called SDRTrunk. With two $20 dongles and an hour of your time, you can be monitoring any simulcast system that you please. An easy step-by-step video for how to do it:
That’s awesome thank you. I had no idea this was an option.
Scanning-Hog
Or get the Bluetail Nano. No computer required, except for firmware updates. Can be used as a base, mobile, or portable. Total cost starts at $150, not including the screen which adds an additional $40-$45. Also has Bluetooth and other cutting edge features not found on other scanners
B.S.
Thank you. I’ll check this out.
Scanning-Hog
The SDR route is a good option if you are using it at home only but it isn't very practical for portable. Yes, it can be done, but you certainly aren't going to just grab it as you head out the door, turn it on as you get in the car, and go. It requires a bit more setup than some desire. A very good option but might be beyond what the OP wants to do. I see this as more for a diehard scanning hobbyist who is looking for new talkgroups or frequencies, etc., and not a basic scanning hobbyist who just wants to hear the action as easily as possible.
The SDS models from Uniden are the best you can get at this point. If the price is something you can afford then go that route. Could always get an SDR and set that up at home at some point, too. The video is a good look at the possibilities for sure.
Thats very cool. I’m kind of a radio dork (HAM Enthusiast) so I’ll likely go both routes. It’s nice to know there is a lower entry point cost wise.
Blackswan73
Central Indiana
Here is a thread about the new Nano
I have one on order😋
B.S.
03msc
RF is RF
The Natural State
Something like the SDS100 would certainly be an easier option to use while out and about than an SDR setup. But, the SDRs are nice and you can do a lot of things with them so you may want to consider that, too, for home. Definitely a lot to play with between those two (or even just with one). Hope you get something soon so you can begin monitoring the airwaves!
Scanning-Hog
B.S.
Blackswan73
Central Indiana
You will also need a WIO terminal. These are available from several sources. For example Amazon, digikey, eBay, or from Seed direct
B.S.
Blackswan73
Central Indiana
B.S.
You can also go here for support and updates
There is also a Bluetail section on this forum
B.S.
Scanning-Hog
B.S.
Thank you.
Quick question 🙋
So the Nano dosn’t need any antenna? Just the display and an SD card, right. Also, if it has an internal antenna does it have the option of adding an upgraded antenna?
Would it be smart to get the F-RAM option, what’s the benefits vs the NOR Flash option?
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
B.S.
Bluetooth? Are you sure about that?
Blackswan73
Central Indiana
Absolutely! Bluetooth is via the WIO terminal. It is built in. The Nano plugs into the WIO, and as a result you can use Bluetooth speakers, headphones, earpieces, etc. with the Nano
B.S.
KevinC
32D2T/957.282
Super Moderator
B.S.
Hmm…so the current Wio FW supports BT for the Nano? I must have missed that. Can you provide a link?
ETA…I also didn’t realize the Nano supplied audio to the Wio terminal.
Blackswan73
Central Indiana
I stand corrected. I assumed since the Nano connects directly to the WIO, that the the Nano would be able to use the Bluetooth Transmitter in the WIO terminal
B.S.
KevinC
32D2T/957.282
Super Moderator
B.S.
Understood. I just didn’t want someone to expect BT capability and be disappointed when they find out it doesn’t have it.
