scanning edacs freq's
skanca
need help -- unable to receive programmed edacs system frequencies when in the trunk scan mode on bc898t. Can receive nice and clear when manually selecting channels. Any ideas ???
D
DaveNF2G
Guest
The four basic rules for programming EDACS into any scanner:
1) The BANK must be in EDACS trunking mode.
2) Each CHANNEL must be in EDACS trunking mode.
3) Channels must be entered in LCN order into corresponding scanner memory channels. Beware of using "channel 0" in a bank.
4) If you have NO TALKGROUPS programmed, then you must use ID SEARCH mode rather than ID Scan mode.
skanca
thanks for the 4-1-1 . i'll try reprogramming to make sure i didnt miss something...
