Scanning Problem
Mags
Old Saybrook CT.
I own both the 685 D and the 250D and have purchased and had them both programmed when they first came out. On my 685D I only monitor the CSP. Suddenly as I'm driving along I noticed after a while the 685D ( with card installed) wasn't picking up any transmissions but my 250D was.. HELP!!!
What went wrong?
joetnymedic
West Haven, CT
is the card turned on? also you may want to make sure the scanner didn"t reset of turn off the trunking somehow
joe
(ps you mean 785 right)
800crazy1
CHICOPEE
check and make sure the plan didnt reset itself somehow to off......this has happend to me from time to time , yesterday as a matter of fact! i noticed CSP awful quiet on my way home from hartford to springfield , i went and checked and sure enough the plan was off , reset it to plan #2 and that solved it!
scannerfreak
Well Known Member
Indiana
"Plan" is an Uniden setting you have to program when you are using Control Channel Only mode read pages 66 and 67 of the manual and you'll find out everything you need to know!
how about the local data channel? was it locked out? the only way i have programmed these radios for csp is- i put in all of the frequencies and talkgroups that are listed and then make sure that i have the correct data channel turned on. thru alot of testing (thanks ed ) all around the state, it seems to work the best. it takes a little bit of work to do it this way, but the feedback has been good. hope this helps bill simpson
