The manual says Scroll to "Set quick key" but it doesn't explain what you use to scroll to it?
Thanks!Connecticut,
all his other questions are about Connecticut.
so i will go with that.
In answer to your question, you twist the top of unit knob to scroll.The manual says Scroll to "Set quick key" but it doesn't explain what you use to scroll to it?
It is a conventional frequency. It does explain what controls to use to scroll to that system- whether it is the knob, button, etc. Thanks.The manual says Scroll to "Set quick key" but it doesn't explain what you use to scroll to it?
I did not see your post #2. Thank You. I have tried the Function than quick key number, but there is no indication that this is "toggled off" or not- no confirmation.. One needs a graduate degree to figure this out,Did you see my previous post #2. I know now that you are in CT.
See if this helps.One needs a graduate degree to figure this out,
thank you...See if this helps.
It explains the display.
And this explains how to toggle things on and off.
Take the time to read and experiment,
