SDR# cannot find UniTrunker XML file?
So Far Away....
started running SDR# with an rtl2832 dongle,,SDR works fine,but im trying to set up the uniTrunker
and when i go to the install directory i get an error,,unitrunker.xml config file not found..
any ideas..what am i missing?
mk262
Flagler County
Post a picture of the error, something doesn't add up here.
You might need to point to the C:\users\user\local settings\appdata\unitrunker directory.
So Far Away....
ok,got it squared up but now SDR is crashing..
im going to delete all and reinstall.try a clean start.
for some reason UNI was not created in the appdata
created it,then reinstalled uni,then all the files were there.
it'll work out.
So Far Away....
I think im having an issue with the config file..
this one causes sdr to crash
looking at it,,it looks like the string for trunker down the bottom is incomplete.
trying different config files to see how it works out..
<?xml version="1.0" encoding="utf-8" ?>
<configuration>
<configSections>
<section name="frontendPlugins" type="System.Configuration.NameValueSectionHandler,System, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
<section name="sharpPlugins" type="System.Configuration.NameValueSectionHandler,System, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/>
</configSections>
<appSettings file="">
<clear />
<add key="fftOffset" value="-40.0" />
<add key="automaticIQBalancePasses" value="5" />
<add key="pllPhaseAdjM" value="0.0" />
<add key="pllPhaseAdjB" value="-1.75" />
<add key="deemphasisTime" value="50" />
<add key="gradient" value="4A0000,750000,9F0000,C60000,FF0000,FE6D16,FFFF00,1E90FF,000091,000050,000030,000020,000000" />
<add key="spectrumAnalyzerGradient" value="FFFFFF,ADD8E6,1E90FF,000050,000000" />
<add key="spectrumAnalyzerColor" value="FFFFFF" />
<add key="fillSpectrumAnalyzer" value="yes" />
<add key="funcubeFrequencyCorrection" value="-21.0" />
<add key="softrockFrequencyMultiplier" value="4" />
<add key="RTLBufferLength" value="16384" />
<add key="minOutputSampleRate" value="32000" />
<add key="timestampInterval" value="100" />
<add key="SDRIQReadBlockCount" value="1" />
<add key="centerScrollLimit" value="5000" />
<add key="SDRIQOutFifoBlockCount" value="0" />
<add key="spectrumAnalyzerAttack" value="0.9" />
<add key="spectrumAnalyzerDecay" value="0.7" />
<add key="waterfallAttack" value="1" />
<add key="waterfallDecay" value="0.9" />
<add key="useTimeMarkers" value="False" />
<add key="fftSpeed" value="40" />
<add key="fftContrast" value="0" />
<add key="fftWindowType" value="3" />
<add key="fftView" value="2" />
<add key="fftResolution" value="3" />
<add key="detectorType" value="0" />
<add key="useAGC" value="True" />
<add key="agcThreshold" value="-100" />
<add key="agcDecay" value="100" />
<add key="agcSlope" value="0" />
<add key="agcHang" value="True" />
<add key="frequencyShift" value="0" />
<add key="frequencyShiftEnabled" value="False" />
<add key="swapIQ" value="False" />
<add key="correctIQ" value="True" />
<add key="markPeaks" value="False" />
<add key="fmStereo" value="False" />
<add key="filterAudio" value="True" />
<add key="latency" value="100" />
<add key="sampleRate" value="48000 sample/sec" />
<add key="audioGain" value="30" />
<add key="windowState" value="0" />
<add key="windowPosition" value="154,177" />
<add key="windowSize" value="963,754" />
<add key="collapsiblePanelStates" value="1,1,1,1,1,0,0" />
<add key="splitterPosition" value="212" />
<add key="iqSource" value="3" />
<add key="waveFile" value="" />
<add key="centerFrequency" value="851400000" />
<add key="vfo" value="851500000" />
<add key="fftDisplayOffset" value="0" />
<add key="fftDisplayRange" value="13" />
<add key="inputDevice" value="[MME] Microsoft Sound Mapper - Input" />
<add key="outputDevice" value="[MME] Microsoft Sound Mapper - Output" />
<add key="spectrumWidth" value="2048000" />
<add key="wfmState" value="180000,100,3,50,0,600,1,17" />
<add key="nfmState" value="8000,300,3,85,1,600,1,12" />
<add key="amState" value="10000,450,3,50,0,600,1,4" />
<add key="lsbState" value="2400,500,3,50,0,600,1,1" />
<add key="usbState" value="2400,500,3,50,0,600,1,1" />
<add key="dsbState" value="6000,500,3,50,0,600,1,1" />
<add key="cwlState" value="300,800,3,50,0,600,1,1" />
<add key="cwuState" value="300,800,3,50,0,600,1,1" />
<add key="rawState" value="10000,450,3,50,0,600,1,4" />
<add key="RTLSampleRate" value="3" />
<add key="RTLSamplingMode" value="0" />
<add key="RTLOffsetTuning" value="False" />
<add key="RTLFrequencyCorrection" value="0" />
<add key="RTLChipAgc" value="False" />
<add key="RTLTunerAgc" value="False" />
<add key="RTLTunerGain" value="13" />
</appSettings>
<frontendPlugins>
<add key="SoftRock / Si570" value="SDRSharp.SoftRock.SoftRockIO,SDRSharp.SoftRock" />
<add key="FUNcube Dongle Pro" value="SDRSharp.FUNcube.FunCubeIO,SDRSharp.FUNcube" />
<add key="FUNcube Dongle Pro+" value="SDRSharp.FUNcubeProPlus.FunCubeProPlusIO,SDRSharp.FUNcubeProPlus" />
<add key="RTL-SDR / USB" value="SDRSharp.RTLSDR.RtlSdrIO,SDRSharp.RTLSDR" />
<add key="RTL-SDR / TCP" value="SDRSharp.RTLTCP.RtlTcpIO,SDRSharp.RTLTCP" />
<add key="SDR-IQ" value="SDRSharp.SDRIQ.SdrIqIO,SDRSharp.SDRIQ" />
</frontendPlugins>
<sharpPlugins>
<add key="Wave Recorder" value="SDRSharp.WavRecorder.WavRecorderPlugin,SDRSharp.WavRecorder" />
<add key="Frequency Manager" value="SDRSharp.FrequencyManager.FrequencyManagerPlugin,SDRSharp.FrequencyManager" />
<add key="Trunker" value="SDRSharp.Trunker.TrunkerPlugin,SDRSharp.Trunker" />
</sharpPlugins>
</configuration>
