SDR Dongle with channel names and save to file on squelch break
dimab
CT
What I'd like to do - using an Airspy Mini - monitor 6MHz or whatever bandwidth is available with an SDR piece of software, and record any individual transmission that breaks squelch within the receiving range to it's own individual file as an mp3, with appropriate alpha tags (that I define per freq), so that an app like Trunking Recorder can ingest it. I don't need this setup to scan through a predefined list of frequencies (my uniden scanner can do that), I want it parked on some segment of spectrum.
Ideally this runs on Windows, supports airspy or any rtl-sdr, performace not a concern.
Googling hasn't given me enough options to cobble together this functionality.
dimab
CT
Sdrtrunk can be setup to do that (not sure of the airspy mini bandwidth choices)
i use sdrtrunk today, but I only see an option to assign a single dongle to a single freq. am I missing an option to assign it more than 1, with alpha tags (all within the dongle's receive range)?
so far the only way I've found is to create a new system for each individual freq. i want to monitor, even with 1 dongle. this could work, but seems like the wrong approach
dave3825
Suffolk County NY
Pretty sure each freq of interest would need to be set up in SDRT. I did that on one install for aircraft using hackrf
The Linux program looks like you just set hi and lo and it creates entries for what ever it sees in the range.
dimab
CT
There is something like that, but its Linux.
finally got this up and running. appreciate the suggestion, but it's pretty rough, and won't work for my use case.
dimab
CT
What flavor of Linux? I briefly tried Ubuntu and had issues getting Docker to install.
pain in my side kind :)
ubuntu desktop 20.04 ARM 64bit (daily build) inside a Vmware VM. - plucky-desktop-arm64
it ran and worked, but the audio recording was bad, UI is impossible, and ultimately didn't do what I wanted.
dimab
CT
SDR Console is another option. It can setup virtual receivers using the available bandwidth of 1 or many SDR receivers. It can record on squelch break, but cannot define custom naming scheme. Runs on Windows, lots of slick options.
