SDR# Frequency Scanner Window Issue
TerryPavlick
Wallingford PA Villas NJ
Good day
This is probably a simple solution but I could not find anything despite searching various areas on the internet.
For some reason the Frequency Scanner window is chopped off on the right side (only M and part of the H is visible.
I tried Windows functions to open the window wider and tried moving the Activity time s. column to make it shorter but still cannot get the Frequcny column to move so I can see the whole column.
Any help would be appreciated.
Running Windows 11 Home version
TerryPavlick
Mine doesn't look like that at all, I must have an older version --
Yeah I should have the latest version loaded - I even tried reloading it but still looks the same - the plugin is working fine - just wish the full log screen was visible. Not sure if it is SDR and the plug causing the issue or Windows. So the reason for the post
morfis
Yeah trying to figure that out.....searching the different folders for an "about" data message
Top left of the main window. It will be something like 1.0.0.xxxx
Where xxxx is the number people usually refer to
Also, what version of the Frequency Scanner plugin are you using (shown on the bottom of it's confiig panel)?
TerryPavlick
v1.0.0.1920 AirSpy SDR#
with Frequency Scanner running I see the Configure button but opening it I do not see a version number....if you can show me where I should see it I will find it
merlin
DN32su
Will the frequency scanner pannel not drag/resize? Maybe find its cofig file and see/ edit its pixel start/end points.
dave3825
Suffolk County NY
Similar issue reported here...
and more recently, here
TerryPavlick
Yes it will resize but the issue remains - no matter if I make it wider or narrower - it still shows the same view. The column separator just left of the word Frequency does not move either although shows the windows symbology for such an attempt.
dave3825
Suffolk County NY
Common problem is some plug ins work with some versions and some don't. Some get/were updated and some were not. Main reason I still run 1742 before all that floating dock and . net 5 crap started.
morfis
Yeah my configure does not have that many options or tabs
It's an old version.....
You could check the details from the dll file but at this point I would just suggest you download the latest version of the plugin as modified by thewraith. That is more likely to work (though I don't use it with any recent variant of sdrsharp and have never used any radio doftware on windows 11).
There are links to the modified versions in the associated thread here on RR.
TerryPavlick
Morfis
Thank you very much - have installed the Wraith version and things are much better.
I appreciate everyone's help in this thread
Thanks again
Terry
