SDR# Plug-in: Frequency Scanner with HackRF
ka5lug
Natchitoches, LA
I have used the SDR# Frequency scanner plugin for quite a while with the Airspy R2 with no issues - it just runs and runs and runs!
I recently decided to try it with my HackRF to take advantage of the extra bandwidth when scanning. It did double the scan rate ( all of the milair band in less than a second), but after about an hour it will hang. When it hangs, sometimes it will lock SDR# and other times it will cause SDR# to exit. I feel sure its related to the scanner plugin as it does not do this when just monitoring with the HackRF.
Does anyone else use a HackRF with the frequency scanner plugin and have you seen this issue? I am using the most current version of both SDR# and the Plugin.
Thanks!
