I have not used SDR# much other some casual browsing around. I have read in these forums that scanning airband with SDR can be superior than a traditional scanner. I do have a few questions, though.
1) What plugins are needed to scan VHF airband, both for a couple frequencies, and a spread of frequencies?
2) Can someone please explain the process of installing various plugins into SDR#?
3) I have read in these forums that older versions of SDR# work much better than newer versions. Can Someone recommend an older version that works and provide an install file?
4) How do you setup scanning a) a couple CTAF frequencies b) a range of frequencies
5) A majority of my monitoring is when I'm not at home, does SDR# have a recording function?
6) What gain settings do you'll recommend for monitoring airband both for Airspy and RTL, Nooelec devices?
Bonus question: I may sometime try the simple DMR plugin, what is the process for finding and installing this plugin?
Thanks in advance
Thanks in advance
