SDR Radios
KF0SOP
I'm hoping to buy an SDR kit. Does anyone have advice on what to look for?
Enforcer52
Lake Livingston, TX
Depends on what you are wanting to listen too, what bands or particular area of listening. Generally though, you are better off with an outside antenna than one of the little dipoles the kits come with.
Enforcer52
Lake Livingston, TX
As long as it's a genuine RTL-SDR, Noolec, Airspy, etc. any of them should work fine. The antenna is the big factor in receiving any particular frequencies.
Then it is trying different software programs to find one you like and does what you want.
Yeah, I just want to use it for amateur use
While the above people have given good advice, I'm not sure what frequency range you are looking for. That said, I would suggest you read through the below thread, if you haven't. It talks about one persons frustration trying to get frequencies. Some of the info might help you down the road.
AK9R
Staff member
Super Moderator
Central Indiana
If all your are interested in is receiving, we have a whole forum dedicated to Software Defined Receivers.
