SDR# Set Up Issues
N9JCQ
Lake Barrington, IL
Hi guys... Very new to SDRs and pretty PC illiterate. I bought ab RTL-SDR dongle (not a cheap copy) and I have just downloaded and installed the Airspy Windows SDR software package that includes SDR#. The software appears to have installed ok. I have selected "RTL=SDR (USB)" as the source. When I try and turn on the dongle I get an error message saying "No device selected." I assume that the software and port are not talking to each other. I how do I point the software to the dongle?
maus92
Eastern Shore
Scroll down to the Troubleshooting section. Read case 1:
I get the error "No Device Selected" when trying to start the dongle in SDR#.
Make sure you have run the install-rtlsdr.bat file, and that it has successfully downloaded the rtlsdr.dll file into the SDR# folder. If it is not downloaded, check that your folder is not set to "read only" (this sometimes happens automatically if you install into Program Files, so do not install into that folder). Another source of problems is if you have accidentally installed the WinUSB drivers to Bulk Interface 1 instead of 0 with Zadig. If you have done this, then SDR# will not recognize your dongle. To fix it go into device manager or Devices and Printers and uninstall the driver for Bulk Interface 1.
