SDR Sharp 1357 stopped working
moonbounce
Today my SDRSharp version 1357 decided to stop working when using the Frequency Manager and Scanner plugin. It runs fine as long as I don't use the FM and S plugin, It just freezes up and I have to exit out of the program. I have another version (1361) that I can run with no problems so far so I don't think it is the computer or the drivers or anything like that. Also the version 1361 does not have the line like the one below, I honestly don't know how it got into the config file.
I remember in some version you used to have to go into the config file and adjust one line kind of like the one I have posted below. I am just wondering if anyone else has version 1357 do you also show the line below in your config file?
Also what exactly does the author mean by " If your're smart enough to uncomment this, please fix rtl_tcp. Is this line the reason that SDRSharp version 1357 does not want to work on my computer.
<!-- <add key="RTL-SDR (TCP)" value="SDRSharp.RTLTCP.RtlTcpIO,SDRSharp.RTLTCP"/> If you're smart enough to uncomment this, please fix rtl_tcp. -->
MB
moonbounce
So I think I solved my own problem, I just ran as an Administrator and so far it is working?
dave3825
Suffolk County NY
If you never had to run in admin mode before, you did not solve the problem. You just found a work a round. I have 1413, and that stopped working. Wont run in either mode. I also have 1361 and that runs fine. Not sure why 1413 stopped but I read somewhere that 1361 was the most liked or most stable.
moonbounce
I should have mentioned that all copies of SDRSharp that I had in those two account fell under the same spell. Fortunately I have copies on a disc and after deleting the two accounts and creating two new accounts I was able to start fresh. In the new accounts I didn't have to run the SDR versions in Admin mode and the account that they are in is a User account only.
In reference to my original post do you have any idea what that one line means?
MB
dave3825
Suffolk County NY
I believe it adds the rtl tcp source option to sdrsharp. The only time i use my tcp is when I run dsd and fmp. If your just running a usb dongle, you just want rtl_usb. I am not sure why that version was released with that line and text.
https://uk.groups.yahoo.com/neo/groups/SDRSharp/conversations/topics/18393
If you cant view the group, here is the only text was able to find
Hello,
I am running SDRSharp V. 1.0.0.1357 but I don't have the RTL-SDR / TCP source option like I have in my previous SDRSharp V. 1.0.0.1357.
How do I add the TCP source option? thanks
Reply
john_2012_17
Message 2 of 2 , Jul 22, 2015
View Source
Just noticed the TCP line is commented out os SDRSharp.exe.Config
so I have answered my own question. I will have to use the old version for TCP
