SDR Sharp Audio Recordings
flubber2007
Central Illinois
I cannot seem to figure out how to get the the file name include my programmed frequencies that show on frequency Scanner. It seems to be taking the name by the red line but don't know how to name that?Screenshot 2024-01-16 153751.png
thewraith2008
The red line (and default fix 'Unknown' label) shown in the Frequency Scanner channel analyzer indicates that there is no Frequency Manager entry for that frequency (129.450 mHz).
Add a Frequency Manager entry for 129.450 mHz or check that an existing entry is actually 129.450 mHz.
The SDR# VFO and entry frequency must match for the label to be shown.
flubber2007
Central Illinois
Thank you for the reply. I had it to scan only new unsaved frequencies, so it was saving all the frequencies I didnt have labeled. I think i figured it out.
flubber2007
Central Illinois
It seems it is only logging saving the file with the "Navigation: Frequency Manager" names and not "Frequency Manager" plugin?
thewraith2008
You should not be using the built in Frequency Manager with the 'FreqMan' Frequency Manager* at same time.
By adding the MagicLine to plugins.xml, this used to disable the built in Frequency Manager to avoid issues.
Looks like SDR# no longer does this. (why is any ones guess)
Problem with both Frequency Managers been active is if you add frequencies to one, the other does not see it until restart.
Also, on SDR# close, one of the Frequency Managers maybe overwriting (the database) of the other, but in which order who knows.
flubber2007
Central Illinois
I just had the SDR recordings separate into files, then I messed up a setting on one of the software so I re downloaded it to reset settings. Now can't seem to set it back to show the proper "group". Just states "No Group"
/ date / group / frequency / length / + " " + name / time + " " + name + " " + frequency
