SDR Sharp - disable frequency display on Cursor ?
paulmo101
Stoke-on-Trent
Hi
I`m having a play with SDR Sharp and I`ve somehow enabled the frequency display on the cursor. I may have done this through the frequency and scanner plugin. I`ve looked everywhere within the program and tried a few google searches. Neither have solved the issue. Hoping somebody will have an answer to how to disable the frequency display on the cursor. Thanks for looking
PDXh0b0
Woodland, WA
Hi
Can you post a screen shot of what you are describing?
Quint-1-29
South Central, PA
Most SDR programs show the frequency when you hover over the spectrum or waterfall, and you can double-tap to retune. While testing SDRTW alongside DSD+, I noticed that DSD+’s frequency tooltip disappeared when the next grant arrived if I hadn’t double-tap.
dlwtrunked
Hi
A bigger problem for me is that I want the frequency display if I move the cursor inside the received bandwidth sometimes and it will not display then.
paulmo101
Stoke-on-Trent
Hi
Please find screenshot I`m talking about the frequency display 296.8125. Having read further I think its an actual feature of SDR# and cannot be toggled on or off. When I installed SDR# I did not see the frequency display on the cursor but after I had a look around SDR# and frequency manager I noticed it had appeared. Its not a problem just thought I`d broken something before even starting LOL
Thanks for looking All the best
