CanesFan95
Analog already is interoperable.
This web page has a long list of plugins for SDR Sharp, including one for Unitrunker. The Unitrunker plugin instructions are:
1) Extract SDRSharp.Trunker.dll to your SDRSharp install folder
2) Extract Remote.dll to the folder that contains Unitrunker.xml (May be in %APPDATA%, or in the Unitrunker folder)
3) Install Microsoft Visual C++ Redist 2012.1 x86 Edition (even if you have a 64-bit machine)
Download Visual C++ Redistributable for Visual Studio 2012 Update 4 from Official Microsoft Download Center
4) Open SDRSharp.exe.Config and find the line "<sharpPlugins>"
5) After the line "<sharpPlugins>", but before "</sharpPlugins>", add this line:
<add key="Trunker" value="SDRSharp.Trunker.TrunkerPlugin, SDRSharp.Trunker" />
6) Save and close SDRSharp.exe.Config
7) Follow the guide at SDRSharp UniTrunker Support
Notes:
Optimized for SDRSharp Rev 1133, but should work with older versions.
Only tested with rev1133 and rev1132.
See the reddit post for more information:
http://www.reddit.com/r/RTLSDR/comments/1d5jmv/updated_sdrsharp_trunking_plugin_with_settings/
The part I'm stuck on is step # 4 & 5. It says to find find the line <sharpPlugins>, but I'm not finding this in SDRSharp.exe.Config anywhere. Does anyone on here know what to do? Thanks.
Notes:
