SDR to monitor an 800mhz P-25 phase I & II system
dave3825
Suffolk County NY
They don't get linked in a physical way. They all show up in the software and get configured as such.
NooElec works with most programs. The program you linked will not do trunked systems.
boatbod
Talbot Co, MD
This calculation for the number of RTL SDR receivers you need is only applicable if you want to use SDRTrunk as your preferred P25 decoding application. The approach this software takes is to decode the control channel and all of the voice frequencies simultaneously. So you need receivers capable of receiving all of the target site's frequencies at once. Because 1 dongle can only tune about 2MHz worth of spectrum (say, for example, 851-853MHz), you need multiple dongles to span the range of frequencies used by the site.
Other applications work differently. DSD+ Fastlane works more like a traditional scanner, in that it only tunes one channel at a time. This has advantages and disadvantages over other applications. There can be some advantage to using two separate dongles simultaneously, with DSD+ FL, particularly if you're monitoring a busy site and want talkgroup priorities to work especially well.
SDRTrunk has a nice GUI but it typically requires more dongles and some decent cpu to keep up with the decoding.
DSD+FL runs on windows and only requires one dongle
OP25 runs on linux and only requires one dongle, but it needs a bit of persistence (or linux knowledge) to get it set up.
Neither DSD+ nor OP25 have what I would consider a nice gui, but they both excel at decoding.
dave3825
Suffolk County NY
This is 7 dongles in Unitrunker that can work together or independently.
Here are 2 Arispy dongles in SDRTrunk.
1 is doing an 800mhz system and the other is doing 2 700mhz systems
Physical connection is them just plugged into USB ports with pigtail jumpers running into a multicoupler that basically allows multiple devices to share 1 antenna. So 6 of my dongles, and 2 Uniden scanners are connected to 1 antenna.
In DSDPlus, there are files which launch 2 dongles, and files that launch 1 (single dongle mode)
merlin
DN32su
Thank you for the suggestions, I had not considered the importance of selecting the software first...
I am currently running Windows 10 x64 bit on my Dell laptop PC...If that helps any.
I use DSD+ fastlane and the cheaper Noolectric smarT. Does the job well.
