SDR USB Hub recommendations
davejl2001
Looking for recommendations for a good USB hub for multiple SDRs. Also 2.0 hub or 3.0 ? Thanks
belvdr
Always go with the fastest your system supports and I always use a powered hub. I use this one with a single AirSpy R2 and a Uniden scanner. No issues. Personally, I like the USB charging ports so I can charge something without it being connected to the computer.
https://www.amazon.com/dp/B08YNPXPRW
I've had excellent luck with StarTech powered USB hubs for use with multiple SDR dongles (I have experienced issues with other brands). I think mine are USB 2.0 but I don't know how much it matters. I got them used on eBay and now have up to 6 Nooelec dongles running simultaneously off of a single hub (7 simultaneously often worked but sometimes flaked out)
I second the recommendation for a powered hub (I.e. with its own AC adapter) since it can eliminate a lot of flakiness caused by multiple dongles drawing more power than your one original USB port can provide.
maus92
The OP
Keep in mind that PCs have internal USB hubs and controllers, so carefully plan out your "load" splitting in terms of data rate.
