SDR V0.6.0
Ducke
Nova Scotia
Hello all
I just up graded from V0.5.3 to V0.6.0 and have nothing
I can see the feed (Waterfall) and see the calls coming in but no sound.
at first i did get some words intermittent but that's been it.
Any Ideas ?
Enjoi19
Just by the version numbers I’m guessing you’re using SDR Trunk? If so, check your playlist to make sure the talk groups you want are selected for listen.
Also check your gain settings. Adjust and check the decode under the “messages” tab on the selected control channel for sync loss messages.
Check that the JMBE library is visible and working as well - in user preferences.
Ducke
Nova Scotia
sorry about that Yes its SDRTrunk.
Ducke
Nova Scotia
Has anything major changed with HRM Fire? All I'm getting now is HRM transit.
danko139
Wilsons Mills, NC
Before downloading the new version, does V6 support entering the System ID/NAC in the Channels tab? Earlier versions didn't (I am on v0.5.0-alpha6).
In Johnston County NC Harris P25, one of the Control Channels for the Clayton tower is 853.9875, which also happens to be the primary Control Channel for VIPER's Erwin site just over the county line. Without being able to discriminate by System ID, my SDRtrunk setup suddenly locks onto VIPER and starts decoding that whenever the Johnston County Clayton site rolls around that 853.9875 as Control Channel in the rotation. I'm right in between.
I can mitigate this by pointing a yagi at the Clayton site (Erwin is thankfully 180 degrees opposite if I do that) but being able to discriminate by System ID/NAC would save me this trouble. Just wondering if SDRTrunk handles this now.
