- Joined
- Oct 28, 2017
- Messages
- 328
- Reaction score
- 262
FLEX Plugin
This is a somewhat crude first draft at a multi-channel FLEX decoder plugin for SDRSharp version 1830 and later.
It supports a total of eight channels. There are seven pre-programmed channels for the 930 MHz band. The eighth channel follows whatever you click in the waterfall. To get the benefit of covering all pager signals in one band, you need an SDR with adequate usable bandwidth. An Airspy Mini at 6 msps does a perfect job.
12.5 khz spacing is recommended.
There's an Enable checkbox. When checked - a grid window appears. All decoded content appears there.
Limitations
SDRsharp.Flex.Plugins.zip
Inside are three DLL files and an example plugins.xml file. If you copy the files into your "Plugins" folder, you don't need to touch your plugins.xml file.
Limitations
- Lacks a fine-tuning feature. It works best on an SDR that is well calibrated.
- The seven pre-programmed channels are not (yet) editable.
- FLEX only. No POCSAG, ERMES or Mobitex and definitely no RD-LAP.
- Consult the laws in your area before using.
