So Tonight I decided to extend my Dongles and place 2 V3 and 2 V4 RTL-SDR dongles, With 4 Separate antennas. and Set the Personal Setting to Virtual cable Stereo. I Set all the control channels, 1 control for each channel. after configuring the app. I hit play on all 4 Dongles. connected my phone and hear a hot mess. But then I put the head phones on and listened in stereo. and I can listen to 2 different channels at the same time. left will be like Berkeley PD Right will be Richmond PD. and its as clear as day. Its awesome. If 2 Dongles broadcast the same station. It plays in Stereo. I like this. and now my Feed is back to Super active.
If you listen on a phone, it mostly only plays one channel but sometimes looks like it steps over each other. but if you play it on a Pc with a Stereo setup you can listen to 2 areas at the same time. or you can put headphones on and listen to my multi channel feed. Still Fiddling with it. but the more I play with this, the more I like it.
