SDRTrunk sdrtrunk freezez after few hours
ronenp
Hi there
After running SDRTRUNK for few hours i get these errors
11:36:02.239 DEBUG i.g.d.r.AudioRecordingManager - Audio Segment detected with NO TO identifiers [433MB/650MB 66%]
and the software stop working
the spectrum and the waterfall freezes and that's it i can stop and start the tuner with the play stop button but it doesn't do anything
Regards
R
maus92
OCMD
What OS?
What are the hardware specs of the computer - processor, RAM?
What SDR?
What version of SDRTrunk?
What system are you monitoring?
ronenp
windows 10 64 bit ( same happen on windows11)
8GB ram
CPU i5-4460S (alsohappend on the windows 11 with i5-8xxx CPU )
SDR rtl-sdr V3 (also happen with RTL-SDR v1)
Version latest Beta5
System Motorola P25 v2
I dont think it is a computer or SDR related it looks to me as pure software as i mentioned it jappened in two difrents of computers and radio (every PC connected to diffrent radio)
R
maus92
OCMD
It's likely a configuration problem or system resources problem, as I use a slightly more robust i5-6600T CPU that (only) runs SDRTrunk beta 5 24/7 with no issues. Note that an i5-4460S is on the low-end for running this software. What else is running on the machine? Are you recording transmissions? If so, what happens if you disable recording? Can you post an image of Task Manager showing CPU loading?
What specific system are you trying to capture? What is its channel spread? Can you post your startup log?
ronenp
I5-8250U is NOT so slow CPU
it runs only sdrtrunk no recording
it does not let me uplad photo of task manager but the cpu load ia about 15 percent
Specific system will not tell you anything it is not appearing in the database it is trunked p25 v2 system it takes 2 MHZ spread that single dongle can handle where is the start log ? what it name ?
ronenp
i5-800 consider slow machine ?
sdrangel which is much havier system runs perfectly there and as i said before it start ok and as time pass the performance degrade it start to loose decoding of words untill it stop to decode anything
Fall back to Alpha 6, much better for us deadbeats with slower machines.
maus92
OCMD
The 4460S is kinda slow, and the 8250U, a newer but low power 15W part is not a huge amount faster - check out the single thread ratings compared to the i5-6600T:Screen Shot 2022-07-30 at 2.56.31 PM.png
Considering that you are having issues with Beta 5 on both machines, it's likely a configuration issue assuming that you're not trying to run a bunch of other programs simultaneously. You have to adhere to the RR forum specs if you want to upload a screenshot that shows Task Manager / CPU loading. Alpha 6 is a solid release and probably a better fit for your hardware.
The log file opens when you start the program and should be in a visible window on your desktop. You can also find it in your User folder under SDRTrunk/logs - assuming you have used the defaults when setting up the program.
ronenp
I have investigated more
and connected to the same computer hackrf instead of the rtl-sdr didnt touch anything in the software just run it again
and all seems to be stable
so i think the problem is in the driver of the rtlsdr in the software
it work for some time and then it start to loose decode and even doesn't decode the control channel
here is the logfile according to the explain you told me where to find it .
20220730 225717.165 [main] INFO i.g.d.log.ApplicationLog - SDRTrunk Version : 0.5.0-beta5 [20MB/128MB 16%]
20220730 225717.165 [main] INFO i.g.d.log.ApplicationLog - Gradle Version : Gradle 7.4.2 [20MB/128MB 16%]
20220730 225717.165 [main] INFO i.g.d.log.ApplicationLog - Build Timestamp : 2022-07-23T08:15:59.564-0400 [20MB/128MB 16%]
20220730 225717.165 [main] INFO i.g.d.log.ApplicationLog - Build-JDK : 18.0.1 (BellSoft 18.0.1+12 [20MB/128MB 16%]
20220730 225717.165 [main] INFO i.g.d.log.ApplicationLog - Build OS : Linux (amd64 5.15.0-41-generic [20MB/128MB 16%]
20220730 225717.165 [main] INFO i.g.d.log.ApplicationLog - [20MB/128MB 16%]
20220730 225717.165 [main] INFO i.g.d.log.ApplicationLog - ******************************************************************* [20MB/128MB 16%]
20220730 225717.165 [main] INFO i.g.d.log.ApplicationLog - **** sdrtrunk: a trunked radio and digital decoding application *** [20MB/128MB 16%]
20220730 225717.165 [main] INFO i.g.d.log.ApplicationLog - **** website: GitHub - DSheirer/sdrtrunk: A cross-platform java application for decoding, monitoring, recording and streaming trunked mobile and related radio protocols using Software Defined Radios (SDR). Website: *** [20MB/128MB 16%]
20220730 225717.165 [main] INFO i.g.d.log.ApplicationLog - Memory Logging Format: [Used/Allocated PercentUsed%] [20MB/128MB 16%]
20220730 225717.165 [main] INFO i.g.d.log.ApplicationLog - Host OS Name: Windows 11 [20MB/128MB 16%]
20220730 225717.165 [main] INFO i.g.d.log.ApplicationLog - Host OS Arch: amd64 [20MB/128MB 16%]
20220730 225717.165 [main] INFO i.g.d.log.ApplicationLog - Host OS Version: 10.0 [20MB/128MB 16%]
20220730 225717.165 [main] INFO i.g.d.log.ApplicationLog - Host CPU Cores: 8 [20MB/128MB 16%]
20220730 225717.165 [main] INFO i.g.d.log.ApplicationLog - Host Max Java Memory: 1 GB [20MB/128MB 16%]
20220730 225717.165 [main] INFO i.g.d.log.ApplicationLog - Storage Directories: [20MB/128MB 16%]
20220730 225717.165 [main] INFO i.g.d.log.ApplicationLog - Application Root: C:\Users\ronen\SDRTrunk [20MB/128MB 16%]
20220730 225717.165 [main] INFO i.g.d.log.ApplicationLog - Application Log: C:\Users\ronen\SDRTrunk\logs [20MB/128MB 16%]
20220730 225717.165 [main] INFO i.g.d.log.ApplicationLog - Event Log: C:\Users\ronen\SDRTrunk\event_logs [20MB/128MB 16%]
20220730 225717.165 [main] INFO i.g.d.log.ApplicationLog - Playlist: C:\Users\ronen\SDRTrunk\playlist [20MB/128MB 16%]
20220730 225717.165 [main] INFO i.g.d.log.ApplicationLog - Recordings: C:\Users\ronen\SDRTrunk\recordings [20MB/128MB 16%]
20220730 225717.165 [main] INFO i.g.dsheirer.util.ThreadPool - Application thread pool created SCHEDULED and CACHED executors threads [20MB/128MB 16%]
20220730 225717.165 [main] INFO i.github.dsheirer.gui.SDRTrunk - Home path: C:\Users\ronen\SDRTrunk [20MB/128MB 16%]
20220730 225717.165 [main] INFO i.g.d.p.SystemProperties - SystemProperties - loaded [C:\Users\ronen\SDRTrunk\SDRTrunk.properties] [20MB/128MB 16%]
20220730 225717.165 [main] INFO i.g.d.p.SystemProperties - SystemProperties - application properties loaded [C:\Users\ronen\SDRTrunk\SDRTrunk.properties] [20MB/128MB 16%]
20220730 225717.399 [main] INFO i.g.d.s.t.manager.TunerManager - Discovering tuners ... [8MB/27MB 31%]
20220730 225717.477 [main] INFO i.g.d.s.t.manager.TunerManager - LibUsb API Version: 1.0.262 [9MB/27MB 35%]
20220730 225717.493 [main] INFO i.g.d.s.t.manager.TunerManager - LibUsb Version: 1.0.22.11312 [9MB/27MB 35%]
20220730 225717.508 [main] INFO i.g.d.s.t.manager.TunerManager - LibUsb - discovered [5] potential usb devices [9MB/27MB 35%]
20220730 225717.524 [main] INFO i.g.d.s.t.manager.TunerManager - Discovered tuner at USB Bus [1] Port [2] Tuner Class [RTL-2832] [10MB/27MB 37%]
20220730 225717.524 [main] INFO i.g.d.s.t.manager.TunerManager - Tuner: USB Tuner - RTL-2832 USB Bus:1 Port:2 - Added / Starting ... [10MB/27MB 37%]
20220730 225718.971 [main] INFO i.g.d.d.f.c.ComplexPolyphaseChannelizerM2 - Sample Rate [2400000.0] providing [96] channels at [25000.0] Hz each [13MB/27MB 50%]
20220730 225718.971 [main] INFO i.g.d.s.t.manager.TunerManager - Tuner: USB Tuner - RTL-2832 USB Bus:1 Port:2 - Applying Tuner Configuration [13MB/27MB 50%]
20220730 225719.283 [main] INFO i.g.d.s.t.manager.TunerManager - LibUsb Hotplug event notification Is Not Supported on this platform. [14MB/27MB 51%]
20220730 225719.299 [main] INFO i.g.d.settings.SettingsManager - SettingsManager - loading settings file [C:\Users\ronen\SDRTrunk\settings\settings.xml] [14MB/27MB 51%]
20220730 225719.637 [main] WARN i.g.d.vector.VectorUtilities - CPU supports maximum SIMD instructions of Species[float, 8, S_256_BIT] [9MB/29MB 32%]
20220730 225720.209 [main] INFO i.g.d.playlist.PlaylistManager - Loading playlist [C:\Users\ronen\SDRTrunk\playlist\police.xml] [17MB/29MB 60%]
20220730 225720.297 [main] INFO i.github.dsheirer.gui.SDRTrunk - starting main application gui [22MB/29MB 76%]
20220730 225731.623 [sdrtrunk scheduled thread 3] INFO i.g.d.c.c.ChannelAutoStartFrame - Starting [1] now - timer invoked [63MB/79MB 80%]
20220730 225731.676 [sdrtrunk scheduled thread 3] INFO i.g.d.a.c.mbe.JmbeAudioModule - Loading JMBE library from [C:\Users\ronen\SDRTrunk\jmbe\jmbe-1.0.9.jar] [26MB/79MB 33%]
20220730 225731.684 [sdrtrunk scheduled thread 3] INFO i.g.d.a.c.mbe.JmbeAudioModule - JMBE audio conversion library loaded: JMBE Audio Conversion Library v1.0.9 [26MB/79MB 33%]
20220730 225731.685 [sdrtrunk scheduled thread 3] INFO i.g.d.a.c.mbe.ImbeAudioModule - JMBE audio conversion library IMBE CODEC successfully loaded - P25-1 audio will be available [26MB/79MB 33%]
20220730 225731.706 [sdrtrunk scheduled thread 3] INFO i.g.d.d.f.c.ComplexPolyphaseChannelizerM2 - Sample Rate [2400000.0] providing [96] channels at [25000.0] Hz each [29MB/79MB 37%]
20220730 225732.839 [sdrtrunk polyphase channel] INFO i.g.d.a.c.mbe.AmbeAudioModule - AMBE CODEC successfully loaded - P25-2/DMR/NXDN audio will be available [85MB/111MB 77%]
20220730 225812.548 [sdrtrunk scheduled thread 1] INFO i.g.d.s.t.m.FrequencyErrorCorrectionManager - Auto-Correcting Tuner PPM to [-2.7] [109MB/161MB 68%]
20220730 232106.006 [AWT-EventQueue-0] INFO i.github.dsheirer.gui.SDRTrunk - Application shutdown started ... [234MB/327MB 71%]
20220730 232106.017 [AWT-EventQueue-0] INFO i.github.dsheirer.gui.SDRTrunk - Stopping channels ... [240MB/327MB 73%]
20220730 232106.018 [AWT-EventQueue-0] INFO i.github.dsheirer.gui.SDRTrunk - Stopping spectral display ... [240MB/327MB 73%]
20220730 232106.020 [AWT-EventQueue-0] INFO i.github.dsheirer.gui.SDRTrunk - Stopping tuners ... [241MB/327MB 73%]
20220730 232106.021 [AWT-EventQueue-0] INFO i.g.d.s.t.m.DiscoveredTuner - Stopping Tuner: RTL-2832 USB Bus:1 Port:2 [241MB/327MB 73%]
20220730 232106.021 [AWT-EventQueue-0] INFO i.github.dsheirer.gui.SDRTrunk - Shutdown complete. [241MB/327MB 73%]
20220730 232106.021 [AWT-EventQueue-0] INFO i.g.d.log.ApplicationLog - Stopping application logging [241MB/327MB 73%]
maus92
OCMD
I doubt it's the driver for the RTL device in the SDRT software because most other people are not reporting problems. It's possible that you did not install the SDR driver properly under Windows via Zadig - a common mistake. But another thing to consider is if the RTL device itself is failing due to heat buildup, poor construction, or counterfeiting - it does happen (I've had a Nooelec SDR burn up.)
I do see one WARNing in the log:
but it's probably inconsequential. It has to do with the low end / low power CPUs you are using that don't have all the bells and whistles of full power / newer i5 processors.
