This one is both dongles connected via the USB hub, also on the outside antenna.
RTL based dongles (as well as Airspy, SDRplay, etc.), are in fact well suited for this very thing. They simply receive whatever signal is out there without destroying any of the components of it. The software then does the demodulating of the full, unmolested signal.Better receivers can deal with signalling from 2 or more subsites, but RTL-based SDRs are not optimized for this use. Even public safety grade radios can suffer with extremely strong signals from multiple subsites.
That is good news. One thing about the Simulcast systems is that you can get Distortion. The only way I fixed this problem on my local system was to use a 700/800 MHz Yagi antenna and point it at one of the sites. I get 100% of the calls with no garbled transmission
For the yagi, does it need to be clear line of sight (above the rooftops)?
Public safety grade radios can have issues with "simulcast distortion." We just reconfigured antennas at one of our simulcast subsites to fix a coverage issue, and had to verify that we would not introducing distortion. So yea, they can be affected, according to the Motorola engineer in charge of that project.RTL based dongles (as well as Airspy, SDRplay, etc.), are in fact well suited for this very thing. They simply receive whatever signal is out there without destroying any of the components of it. The software then does the demodulating of the full, unmolested signal.
Oh and public safety grade radios don't have issues with strong signals from multiple subsites, otherwise they'd be unusable in some overlap areas. 🤦♂️
