SDRuno intermittent freezing while scanning.
danhes
Running a RSP1 with SDRuno and DSSPlus to scan local NXDN, DMR, and P25 traffic. I keep getting intermittent hang up, freezing, and a warning that says "no audio device driver present" every few hours?
Computer CPU <50%, SDR receiver <10%.
Cant close and of the SDRuno windows and have to go into task manager and force close it. Restart the computer, fire SDRuno and DSDPlus back up, and it'll work fine for another few hours to a day?
Anything else i could look into to fix this? Screenshot 2024-04-06 174120.png
sunwave
Oklahoma
In RX Control check if the WME Ouput Device box is blank. It will be the second tab that says "Out". That "Out" means output. Output to sound card. If you made changes to your output devices in Windows sound settings while SDRuno is running, that pop up happens then you lose audio and the Main/Aux SP windows just shows lines or flat out freezes. Force close SDRuno then re-open it then select your default sound device. Do all your sound settings while SDRuno is not running.
Other scenarios that may cause it:
If you removed a device driver that error happens while SDRuno is running
If a driver stopped working, while SDRuno is running, because a sound card nuked itself then that will happen.
danhes
Thank you for response. I have checked the RX settings. Nothing has changed anytime I've checked. I have one virtual audio cable feeding DSD Plus from SDRUno, then another from DSD feeding a private Zello receive only gateway for a few local agencies. Is there any possible background processes somewhere that i need to check and see if they're hanging up, or windows is possibly trying to change?
sunwave
Oklahoma
I can't think of anything. I have yet to have that problem. The only thing I can suggest is to fill out this support form with accurate email, name. Give them the same description of the issue with screenshot. There is a file option. You will need your RSP1 serial number. https://www.sdrplay.com/helpsys/pre3.php
They usually respond in 48 hours.
AngWay
Curious
Buchanan, Va
Anything else i could look into to fix this? View attachment 159769
how do you get sdruno to stop when someone is talking and skip again after they stop? is that possible to do? i was thinking about doing the same thing but all i can get is a list of channels to scan but it doesn't stop .
