Turk_WLF
I’m not sure what is going on with My SDS 100, it just started to lock on to my Local Law TAC Channels (3 Channels) and will not scan. On the TAC Channels all you hear is Cracking and Popping.
When I start the scanner, it loads my favorites & then one of the TAC channels stays on & above the “System” soft button is a “NFM”. Sometimes I can press the “Channel” soft button & the scanner will cycle thru the local channels & then will lock on to 1 of the 3 TAC Channels.
Can anyone assist me with this problem?
Thank you,
Thank you,
