So is it fixed now? Worst case if the card is truly corrupted vs not putting the scanner in Mass Storage mode, is follow the other threads with the card in a PC... format the card and put new loads on it. Pretty straight forward procedure. I just did this upgrading to 16G class 10 cards.
This thread is mine but has links to other threads where this was discussed as well. If you have to go this route use the SD format tool.
Hey folks, I took yet another plunge after reading another thread. It mentioned the units being fast to load and boot when using a higher class SD card. This is true and it is noticeable. Now for me the 100 has always loaded faster than the 200. Just watching the units boot ignoring...
forums.radioreference.com
