Who sells the USB Power/Programming cable for the SDS 100 scanner ?
...that has 4 wires, or comes with a device that gets programmed via a computer should work. I have beheaded many cheap usb mini wires for projects, only to find red & black wires inside the insulation, and they simply won't pass data as the other 2 conductors are missing. They'll power, but they won't program.Any USB mini cable should work. Here's an ebay listing for one
From our FAQ
Programming cable for SDS100 & SDS200?
Can anyone tell me the cable connector types for both theSDS100 and 200 model scanners? USB to micro USB, USB to mini USB???forums.radioreference.com
Mike
If you are going to power and charge, make sure the USB cable has a good gauge wire or the voltage loss will kill the charge with power.
I have that same cable. Works very well. Monoprice, whether ordered through Amazon or direct via their website, has been a good source for many different cables. Their HDMI cables are considerably less expensive than the overpriced ones at big box stores, and work with no problems at all. Besides USB cables of various types, I've also purchase other types.Ok I purchased this one as recommended above. Just got the 6ft one. Here is the link he sent me to.
