There were several YouTube posts about poor reception with the provided SDS100 Antenna. My SDS 200 is connected to Dicone at 40 Ft not a good one to compare against. Any suggestions would be greatly appreciated.
KF5YV
KF5YV
Call is KF5UV. Freqs will be 700 Mhz trunk and VHF band conv.There were several YouTube posts about poor reception with the provided SDS100 Antenna. My SDS 200 is connected to Dicone at 40 Ft not a good one to compare against. Any suggestions would be greatly appreciated.
KF5YV
The 842S is compatible. I use it when I’m in areas requiring VHF and UHF coverage. When I’m home I use the 820S since our system uses both 800 and 700 frequencies.er...it's marked not compatible with the SDS100. The proper link would be here...
SMA SDS100 800MHz REMTRONIX Portable Antenna | ScannerMaster.com
SMA SDS100 800MHz REMTRONIX Portable Antennatinyurl.com
Mike
For the rubber duck variety, the Remtronix 842S triband always got decent reviews and I'm happy with it for on-the-go use.
Amazon has it listed << HERE >>
The 842S is compatible - the listing on Amazon is NOT. See the first bullet. It may be a Chinese knock off
Mike
