what are the filters in sds100 scanners used for
Wide Invert works best on my SDS in my area also.If you are in Rockland County NY, I often have good results using the Wide Invert filter on sites with 700 MHz frequencies. Rockland County Public Safety Communications System (RCPSCS) Trunking System, Rockland County, New York
It's a filter in the scanner, or actually two, that are 10MHz wide that let the RF signal pass to the rest of the receiver. When the filter are set to Off you are then receiving your monitored frequency in the middle of that 10MHz window.what are the filters in sds100 scanners used for
The 10MHz wide filter sit at the IF point in the SDR receiver, where the signal have been mixed to an IF frequency of 265MHz or 380MHz. One problem are that the SDR uses an "intelligent" attenuation called "smart power detector" to reduce its front-end gain whenever it sees a strong signal inside this 10MHz window, and that function cannot be disabled or changed, it uses a fixed setting within the chip.You’re not wrong that overload exists. You’re wrong that it explains this!
I believe you think that the SDR technology in Unidens SDS scanner could be compared to a real SDR receiver like Icoms R8600, but that are not the case as Uniden use a hybrid chip that are mostly analog and only digital at its output. If it where a true SDR receiver it wouldn't have the Function+7 for IF switch or use IF filters at 265MHz and 380MHz.At this point you’re not explaining the SDS filter behavior, you’re forcing everything into a narrative that simply doesn’t survive contact with real-world results.
Your entire argument hinges on this idea that what we’re seeing is just classic front-end overload combined with a wide filter being “shifted” around to dodge interference. That might sound neat on paper, but it collapses the second you compare it to how these radios actually behave in the field.
Right now, you’re trying to reduce a complex SDR behavior down to a single analog-era explanation and it just doesn’t fit.
Ok than, move to sds150 forum. I bought motorola, who cares about it on sds100 filter thread?I bought the SDS 150 and don't mess with Filter Settings anymore
How the filters work are that they try to block interfering signals but the monitored frequency are always withing the filters bandwidth so its signal strength shouldn't change if there's no interference and you test different filter settings. If you see different levels and different data error values with different filter settings then you have interference issues.I like the way filters work. Wide invert filter is most commonly used on many 700 MHZ system's I receive. I see about a -20 -dBm increase. Set it and forget it.
