Is the key pad size any bigger on the sds 150 than the SDS 100? I'm guessing not, since it's not much bigger.
I have Proscan.org for that.Is the key pad size any bigger on the sds 150 than the SDS 100? I'm guessing not, since it's not much bigger.
In Butler County, MO?I have ProScan also. Problem is, I can't get internet at my location. Anything but Broadband and that never, works very well.
The keypads on the SDS100 and SDS150 are identical in size.Is the key pad size any bigger on the sds 150 than the SDS 100? I'm guessing not, since it's not much bigger.
Have you looked into Starlink Home?Yes, I'm in Butler County Mo. I live in a Rural area. Practically a hole in the ground. It's such a valley that everything, is up hill all around me 360 degrees. Cable internet won't come out this way. Houses are few, and too far between. Cable companies won't run lines out this way. Would take a long time and too much expense for the companies. Their expense vs profit, wouldn't be in their best interest.
Sort of like, living in a ditch?Yes, I'm in Butler County Mo. I live in a Rural area. Practically a hole in the ground. It's such a valley that everything, is up hill all around me 360 degrees. Cable internet won't come out this way. Houses are few, and too far between. Cable companies won't run lines out this way. Would take a long time and too much expense for the companies. Their expense vs profit, wouldn't be in their best interest.
on the 150 there is a app called U/aware uses bluetooth and puts it on your cell phone you can fully control the scanner from itYeah, my fingers are a bit large for the keypad on the SDS100.
