SDS 200 pour Saint Eustache
Rolly23
I have a Uniden SDS200. I have done the programming of the RSP2.
I have no problem capturing the firemen of Sainte Therese, Blaiville, Bois Briand, Mascouche, Deux Montagne Repentygé, Saint Annes des Plaines and Terrebonne, but I am in I am unable to capture Saint Eustache.
I put the DMR in my scanner. I even did an ID Search for nothing and returned to Saint Eustache in the RSP25 101 North West bank.
I am in Sainte Thérèse.
Merci
Ubbe
Stockholm, Sweden
If you can have both RSP2 and SDS200 running at the same time then set the SDS200 to the Saint Eustache frequency, Channel+freq+Channel, and set squelch to 0 and listen to it when the RSP2 are receiving Saint Eustache. Change IFX, Fn+7, and try different filters in the scanner Menu/SrchCloCall Opt/Set Filter, until you hear the signal and if it is clear enough it will automatically switch over from analog to digital DMR. Then program that working setting to the frequency and department, or site if you have it programmed as OFT.
/Ubbe
BC_Scan
Vancouver BC
I see that this is in 700/800 MHz P25 P1 system not DMR. Yes, site 101 is the one you want.
Does the scanner see the control channel?
I would isolate the scanner to one bank only for this system and put in ID Search . Are you using whip antenna or do you have separate outdoor antenna? These are the factors you need to look at.
ST-EUSTACHE FIRE​
DECHEXModeAlpha TagDescriptionTag
54200d3b8DSE_INC_ANNGeneral AnnouncementMulti-Dispatch
54201d3b9DSE_INC_GENGeneralFire-Tac
54202d3baDSE_INC_OP1OperationsFire-Tac
54203d3bbDSE_INC_PRVPreventionFire-Tac
54206d3beDSE_ENTMesures d'urgencesInterop
Rolly23
Merci de votre réponse jai une disconne à linterieure de la maison, je vien juste de créer un RSP25 101 juste avec saint eustache mon SQL et a 0 et mon volume et a 11 et la seule fréquence que je voie et le 772.281250 mais jais de son du répéteur. Voïcie des photoimage1.jpegimage2.jpeg
Ubbe
Stockholm, Sweden
The 101 site covers a large area but site 103 covers a smaller area inside the 101 coverage, and both sites cover the Saint Eustache region. The Fire brigades radios could be affiliated to site 103 that could be an umbrella site to pick up most of the users and 101 are picking up the rest.
Scan both sites and set squelch to 2 and you have no use of that "Batt:" display field in a SDS200 so change that to instead be "Digital Error Count" that will show how many errors you have in your received data. You can use IFX and the different filter settings for site 101 and 103 to try and find the best signal with the lowest bit errors, must be below 5.
/Ubbe
Rolly23
Le site 101 couvre une grande superficie, mais le site 103 couvre une plus petite superficie à l’intérieur de la zone 101, et les deux sites couvrent la région de Saint-Eustache. Les radios des pompiers pourraient être affiliées au site 103 qui pourrait être un site parapluie pour capter la plupart des utilisateurs et le 101 ramasser le reste.
Scannez les deux sites et réglez squelch sur 2 et vous n’avez pas besoin d’utiliser ce champ d’affichage « Batt : » dans un SDS200, alors changez-le pour qu’il soit plutôt « Digital Error Count » qui indiquera le nombre d’erreurs que vous avez dans vos données reçues. Vous pouvez utiliser IFX et les différents paramètres de filtre pour les sites 101 et 103 pour essayer de trouver le meilleur signal avec les erreurs binaires les plus faibles, doivent être inférieurs à 5.
/Ubbe
Merci de linformation si je comprends bien, je dois utliser le RSP25 103 et de mettre saint eustache à linterieur du RSP25 3 eje place tu les LCN du RSP25 101 dans le RSP25 103 merci
Ubbe
Stockholm, Sweden
The RR database says that Fire TG's have been updated in september, so check that you have those that BC_Scan are showing.
For your favorite 9 system 9 and department 9 you simply edit the Sites Avoid status to avoid all sites except 101 and 103 to check that you can hear Saint Eustache fire brigade. Use ID Scan and not ID Search as otherwise you will get hits from all TG's in the system. But if you do Avoid to all other departments with TG's except Saint Eustache Fire then you can use ID Search to find any new TG's that are not in the database.
/Ubbe
BC_Scan
Vancouver BC
I have a disturbance inside the house
This is good. I know it's difficult for various reasons, but if you can place this outside and higher up, you might be surprised at how much better reception and distance you will receive from any place.
Rolly23
The RR database says the Fire TGs were updated in September, so check you have the ones BC_Scan shows.
For your favorite 9 System 9 and Department 9, simply change the Sites Avoid status to avoid all sites except 101 and 103 to verify that you can hear the Saint Eustache Fire Department. Use ID Scan and not ID Search, otherwise you will get hits from all TGs in the system. But if you do Avoid to all other departments with TGs except Saint Eustache Fire, you can use ID lookup to find new TGs that are not in the database.
/Ubbe Not
hello I did the test with the RSP25 103 and I placed Saint Eustache in the RSP26 103 ran the scanner all day and then all night nothing and arrived at the lore I placed the LCNs of the 101 with the 103 nothing and arrived. I wonder if it's not the scanner that has a problem or the SD card or the RSSI is too high but I don't know how to lower the RSSI. SE which bothers me the most is that two mountains are very profitable and even MRC de Moncalm prevos.thumbnail_IMG_0685 (1).jpg
Ubbe
Stockholm, Sweden
Do you have any signal strength from site 101 and 103? In the picture it says -96dBm for site 101 which is good enough. If you get -100dBm or better from site 103 then you should receive the St: Eustache Fire if they are using any of those two sites.
Even if you only receive the control channels and not the voice channels you should at least see the Fire TG on the display for a couple of seconds and then it disappears. Going by the coverage map for the system there isn't really any other sites that could be used for the Fire department. In that case they must be using some other system.
Set priority to the TG's for St: Eustache, and also alert sound, as that will allow them to be monitored even when other TG's are in use. If you can monitor more sites then enable those as well and if you hear an alert sound you will know that they are at least using the same system.
As someone has reported updates of the TG's there must be someone who has managed to monitor them in that RSP25 system.
/Ubbe
maplebear
North America
Merci
Did you check your service types were on?
Similar threads
