Kinda makes you wonder - if a user can delay these functions for up to 4 1/2 minutes without apparently any negative impact, why it is necessary to default it to every 1-2 seconds.
FWIW - it still seems that the constant dropping and reacquiring of the CC with the default hold of 0 is a problem given setting it to a higher value in many cases seems to improve performance. However, I've never done any test of this on a very strong signal vs. an "average" or weaker signal. It seems like if the radio is able to determine a signal is -45 dBm vs. -100 dBm, it would spend more time trying to check the weaker one (a sort of 'dynamic hold adjustment') rather than requiring a user to change the default hold time....
