SDS100 - a few oddities...
nessnet
Eastside of Lake WA
I have noticed a couple of quirks on my SDS100.
First
I'd have to put it on a scope to determine the freq. When connected to an external speaker, the audio out, (during a transmission), has a pronounced low frequency 'rumble'. It's fairly low, maybe 30-40Hz, possibly lower?
Does everyone also have it? Does someone have a scope handy they can hook up and determine the freq? I applied multiple notch filters in ProScan, but when in the car, I hook it into the aux input of the car sound system and it really comes through. I suppose I'm going to have to build a filter for the car as well.
Second
My radar detector (V1) was alerting periodically on X band. I figured out that it was doing it when the SDS100 was scanning VHF - looked like 167.XX or 168.XX. Definitely VHF in and around 165-170. It's not putting out any other interference on any other band, at least none that sets off the V1.
nessnet
Eastside of Lake WA
Update:
This may be an artifact of a system. IE: I don't seem to hear the "rumble" on a P25 system I monitor.
The system that seems to have this issue is KCERS (King Co Public Safety). I'll have to do some driving around to see if other systems have this issue.
jonwienke
More Info Coming Soon!
VA
You're hearing the CTCSS tone. It's not being filtered out. You'll only hear it on some analog channels, but not on digital channels. Audio should have a 280Hz high-pass filter on analog channels, and a 100Hz high-pass filter on digital channels.
nessnet
Eastside of Lake WA
Hi Jon,
Yea, I'm hearing it on different systems (analog) as well.
Makes sense that it is CTCSS tone.
"Should".... Paul, you seeing this??
Ubbe
Stockholm, Sweden
It's difficult to make a filter that removes all resudials of a subtone frequency. The small speaker in a scanner cannot reproduce the rest of the low frequency signal but a wider range external speaker will. It is also not unusual that the subtone frequency are not completly 100% pure, either from the transmitter source or from low resolution digital audio processing in the receiver, and have some artifacts that generates products higher up in frequency above the filters range.
A very effective filter would be a auto notch filter and not a fixed hight pass filter. I have it in my Icom receiver and it works really well. It's probably too expensive for a conventional scanner but a SDR application like the SDS100 would have no problem implementing this, just adding a one time cost for the work hours from the firmware coder guy.
/Ubbe
jonwienke
VA
No it isn't. Especially in software. Digital audio editor programs have been doing it for decades. And so do SDR programs like SDR#. In the audio range, there are many consumer-level software packages that can do high-pass and low-pass filters with pretty much complete cutoff within 1-2% of the set frequency.
nessnet
Eastside of Lake WA
Of note here: my 436, in the same setup, didn't have this audio (low freq CTCSS rumble on analog) issue.
I was hoping that this is possibly going to be addressed via firmware...?
Paul??
(should this be reported as a 'bug'?)
jonwienke
VA
Paul??
The 436 filters out CTCSS tones below 100Hz, but you can still hear CTCSS tones above 100Hz.
nessnet
Eastside of Lake WA
I thought about this some more.
Jon, the system I'm hearing this "rumble' on is a Motorola Type II SmartZone.
Seattle-King County Public Safety (KCERS) Trunking System, Seattle, Washington - Scanner Frequencies
It doesn't(??) use CTCSS tones.
I do see up top of the system's RR page a "connect tone" of 83.72.
Another system I'm hearing it on:
Snohomish County Public Safety (SERS) Trunking System, Everett, Washington - Scanner Frequencies
Also Motorola Type II SmartZone
"Connect tone" of: 97.3
jonwienke
VA
The connect tone is the same sort of thing as CTCSS, just in a trunked system instead of a standalone analog frequency.
All of this gets solved if the scanner applies a 260Hz high-pass filter on analog transmissions (except WFM and FMB), and 100Hz high-pass filter on digital transmissions. FMB and WFM should have a high-pass filter of 20Hz.
WFM and FMB should have a 15-20KHz low-pass filter, everything else should have a 3-5KHz low-pass filter.
MAguln8839
MEDWAY
I am hoping this will be addressed soon. Using an external speaker, the tones are very noticeable. The internal speaker does not have a low frequency response and the tones cannot be heard, but very annoying when a better speaker is used with a fuller frequency response.
Ubbe
Stockholm, Sweden
Motorolas Smartzone Smartnet Startsite systems uses a low speed datasignal on the voice channels, it sounds similar as a DCS subtone around 170Hz.
If it is as Jon says that digital channels in a scanner only filters out audio up to 100Hz then the 170Hz will pass through, if a smartzone system have been thought by mistake to be digital in the scanner as it is a trunked system. A typical bug in a new scanner that might not have taken in all knowledge learnt from previous scanners, new folks doing the firmware.
/Ubbe
