They've not said much other than they're hoping for a full recovery.Sure hope the officer was okay. Really pisses me off everytime that happens. All my family have been very lucky. My dad, two uncles and 5 cousins.
While I don't know that the exact scenario that post was about would pertain to me, it does cause me to pause and wonder if it's worth the outlay. We have little UHF public service in my area and at home I cover that with either my BCD 536 or one of the multiple other ham radios I have that receive there when I'm in the mood to monitor that. My local town is still dispatched on VHF analog and again that's covered by the 536. In a pinch I do have a G5 (well two honestly) that have VHF in them and if out and about I can switch to the fire analog stuff there, I"m not so much about listening to the call outs to the nursing home to assist fall pick ups and stuff which is a lot of it.So, a post about the SDS150 has convinced me without doubt that I should get a G5 which I will do in the next couple days.
SDS150: - Uniden's Official SDS150 Tech Discussion
Just send a dot . to its micro usb port using ProScan or other terminal program like PuTTY and see if it answers back with R840 that are the receiver chip used in the other SDS scanners. /Ubbe Does the SDS150 have 2 USB ports? If not, there may not be a way to issue diagnostic commands as you...forums.radioreference.com
I will order the G5 with 450-512 Mhz. Comparing reports here on the G series pagers with posts about the SDS150 performance helped me make an informed decision. Thanks for all the information. I am excited to get a receiver that can provide excellent coverage and audio with local LSM systems.
I will use a BCD325P2 or HP2 for anything the G5 does not cover. In fact it should be a good combo. The BCD325P2 and HP2 can cover analog and the 240 site NC Viper system for me. The G5 can cover my local county, adjacent counties and the 3 Viper LSM sites if I am ever near one. Of course one at a time which is just fine.
Yep. $950 for a radio that has intermod issues that a BCD996T and BCD536HP do not is not appealing to me. Also the reports of audio quality concern me.While I don't know that the exact scenario that post was about would pertain to me, it does cause me to pause and wonder if it's worth the outlay.
Thanks. All suggestions are much appreciated.The only down side to the G5 is you can't program on the fly. Make knob position #8 your travel channels!
Yeah, I do understand all that. The wildcard will only be for times when something remote may not be programmed. In my county the traffic is not continuously busy on all TGs, but in Mecklenburg County it would probably be unusable that way. Other adjacent counties will be similar to mine.You have to remember it's a pager working as a scanner. The wildcard usually gets you more traffic you don't want to listen to. Plus all you will get is a TG number. You don't control the G5 like a scanner. It's the best for simulcast.
My main reason also is good performance on P25 LSM with audio far better than the SDS100. In reality, the BCD325P2 can often receive LSM well enough to discover anything else or supplement those not often needed TGs that I would not want to waste space programming in the G5.As you aware, and like most if not all professional grade radios Unication are not designed to program on the fly. G5 is a pro pager that best combat LSM and captures 700/800 P25 signals. It just works.
My main reason to invest in my G5 was to recoup on a device that would designed to deliver the best key ups on our local P25/P2 with solid forum factor , exceptional battery life and clear audio. I don’t monitor analog nor VHF/UHF with it. Right tool for the right mission. If I plan on traveling, I invest the time in pre programming and assigning knob positions. I chose not to play where’s Waldo or look for unknown TG s with my G5.
Agreed but it did come in handy for a spur of the moment side trip on a vacation we took last fall with a Wild card group and scan position.If I plan on traveling, I invest the time in pre programming and assigning knob positions.
Ya if I have to use it unplanned at least you can lock out up to 64 TG's, not that I've ever locked out that many but still comes in handy on occasion. While I do occasionally miss the TG "name" while out and about, usually it doesn't take much to figure out if you're listening to animal control or something you really might want to listen to. As mentioned above I try and do appropriate planning prior to taking it out of the area.The wildcard usually gets you more traffic you don't want to listen to. Plus all you will get is a TG number.
My sole reason in the beginning was to monitor our county's simulcast system, and the county next to me. I agree using the Unication for other things may seen like a waste however in some rare applications I do use mine to listen to the local FD on VHF and also a couple other VHF things I may have the desire to hear while I'm out and about. It spends 99% of its life though on P-25 trunking be it simulcast or single site depending on my location. It was honestly well after the fact I put the VHF stuff in there, I figured it's in there why not. I don't always have the plethora of radios with me like I do at home.My main reason to invest in my G5 was to recoup on a device that would designed to deliver the best key ups on our local P25/P2 with solid forum factor , exceptional battery life and clear audio
Can you comment on what you think is the reception quality of analog VHF on the G5 given it only uses an internal antenna for VHF? Thanks.Agreed but it did come in handy for a spur of the moment side trip on a vacation we took last fall with a Wild card group and scan position.
All in all for monitoring a P-25 trunking system, be it single site or especially simulcast, given the battery life and great audio, if there's something besides an actual subscriber radio that beats it, I haven't found it yet.
I can only compare it to what I tested it to here. On the internal antenna, using the weather band frequencies as a test, it outperformed an SDS 100 with some kind of long ham antenna on it which the owner of the radio I had on it.Can you comment on what you think is the reception quality of analog VHF on the G5 given it only uses an internal antenna for VHF? Thanks.
Well that is encouraging. Thanks for the report. I am still leaning to UHF. I listen to national parks, mainly the Blue Ridge Parkway on single channel P25. But that is not very often, and I have the BCD325P2 that does that very well.I can only compare it to what I tested it to here. On the internal antenna, using the weather band frequencies as a test, it outperformed an SDS 100 with some kind of long ham antenna on it which the owner of the radio I had on it.
Regarding my BCD 536 with a telescoping antenna on it, the 536 was slightly better it seemed but you know, it was pretty close.
On a ham HT I checked it on, the Ham HT won
by a pretty fair margin but it was a dual band Ham HT so that wasn't surprising.
Coming thru MO listening to the Moswin System, on VHF, I guess it did OK but I needed it up on the visor to work very well, next trip we had it in the Amplified charger and I had a little Magnet mount on the car, and that worked much better it seems. All and all I works acceptably well I think for an internal antenna. It's not a 3 DB gain antenna out there no, but for what it is, works ok or to me it does.
I am really anxious to experience much better reception and audio than the SDS100.I have never felt the need to install an outdoor antennas for my cars nor town home. The supplied G5 antenna antenna does an amazing job of capturing our local P25/P2 system. If I need an extra dot then the amp charger does the heavy lifting. The TT are within +- 5 miles of my QTH. Although I seldom monitor more than 5 miles from home in my cars, the G5/stubby antenna clipped to the visor, I can monitor my entire county of 2000 SQ miles and county to the south.
That's exactly what I want. Thanks.All in all for monitoring a P-25 trunking system, be it single site or especially simulcast, given the battery life and great audio, if there's something besides an actual subscriber radio that beats it, I haven't found it yet.
This also has been my findings.
The G2 in VHF will obviously use the external antenna for its band. I will only say the scanning speed of the Unication is slow to me it seems. While I would consider one for monitoring the MOSWIN system on p-25 trunking I'm not sure to me it would be other wise worth it for conventional scanning. You're limited to 16 conventional frequencies per knob position which is fine if that's all you need but honestly as a scanner for conventional it fails compared to an "actual scanner".am pleased with the G5 with UHF 450-512 as I expect I will be, I am considering a G2 VHF later
The 700/800 reception was and has been awesome. I only used the magnet mount on the car for the VHF MOSWIN trunking system over in MO. At home they sit in the charger with either the old RadioShack 800 antenna or the Remtronix that to me is a duplicate that antenna. My G4 charger has the 800 Remtronix with the right angle plug on it and while it works fine, I think the other two are a little better.In my case the supplied blue band antenna is trully a miracle antenna.
