Opted not to include an expensive option that many would never need nor use, so as to keep the sticker shock manageable.
Wondering why Uniden would not just include a GPS as a standard part of the unit.
I have 4 536's 4 996P2's 1 436 and inline to get a SDS100 why would I want to pay for 10 GPS units when I only need 2 and can switch them to any one of the 10 at any time?
Yes with the BC-UTGC cable in the attachment the SDS100 will work with Uniden's GPS.I don't understand, will the GPS with the 536, or the 436, work with the SDS100.
Don't want to have to buy, another GPS.
You can order it now if stock is available. I also believe Scanner Master has them in stock.Can I order the cabling, from Uniden when the SDS, becomes available?
My concern there is what does that do to the warranty, say on the new SDS100? Will that void the warranty? I would think it would, but I may be wrong.
Was in the RR database. I did however delete the confirmed LCN and ran the finder last year when testing NXDN on the X36HP series. That function worked well and confirmed all 9 LCN's fairly quick.Jason Thankyou for the NXDN sounds great.
Was that system in the RR Database or did you use LCN finder for the ID's?
Just tested Uniden's BC-UTGC GPS adapter cable with the BC-GPSK & SDS100 for my trip back home from Columbus testing this evening.
Everything works flawlessly and I was scanning the Full Database, powering and charging the SDS100 simultaneously. The GPS puck & SDS100 is being powered/charged by my Anker Power Drive 2 through the adapter cable. I'd recommend a 2+ amp clean power source as the scanner can pull 1+ amp by itself at full volume, open squelch and being all lit up!
Houk![]()
Sent from my Moto G (4) using Tapatalk
